Old 12-31-2004, 02:15 PM   #1
WRXerRacer
Member#: 39181
2002 Impreza WRX
WR BLUE
Impreza WRX STi Jdm ej207 swap into wrx is finished. Its crazy.
FinallY got my car back all done. Full v7 ecu and engine swap. the car runs great and i filled up on 100 octane until i remap my ecu. for 93 octane . Is it safe to run on 93 octane with. out detonation. I am sending my ecu to kingpin for a remap. How do i tell if the Avcs is working.? The car pulls very strong and boosts at 18-19psi which i thing is a little high. My a/f gauge shows the car is runnin reach during full boost. which is safe as long my motor doesnt blowup like my wrx motor twice. Hopefully this will be a relaible daily driver and fun swap. Any help would be appreciated above the above questions. Thanks guys i will post pics of the Swap. And i also have all my old wrx parts for sale from the vishnu stage 2 kit. And parts of the motor. Anyone interested? Greddy profec B spec 2, Sti injectors, vf 30 turbo, wrx stock intake manifold, samco intercooler hoses, stock wrx intercooler & turbo, and many other stck wrx parts.
WRXerRacer is offline   Reply With Quote
Old 12-31-2004, 02:40 PM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
You might want to post your parts over in the Private FS classifieds, they get a good bit more traffic than the conversions forum.
Otherwise, glad to hear that another swap has gone well. That boost level does seem a little high... is that a spike, or is it getting sustained 18-19psi?
/Andrew
Kha0S is offline   Reply With Quote
Old 12-31-2004, 03:52 PM   #3
WRXerRacer
Member#: 39181
2002 Impreza WRX
WR BLUE
It stays pretty constant throughout the gear on full throttle at 18psi, but tapers to 14psi towards 6800 rpm
Old 01-01-2005, 02:29 AM   #4
gpatmac
Member#: 18446
2002 WRX wagon
psm
I don't want to tell you something then have it blow up on both of us, but so long as you keep out of the boost (and try to stay off of hills), you're safe running 93 octane. Is it higher or lower compression, though?
So long as you're below boost, it's an NA car (obviously.)
gpatmac is offline   Reply With Quote
Old 01-01-2005, 05:57 PM   #5
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
I ran 93 octane on mine till i got a utec and tune, but I only ran it on wastegate boost, ~11psi on my vf22.
George
SonicYelloWRX is offline   Reply With Quote
Old 01-02-2005, 01:12 AM   #6
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
JDM STI V7 motor swap
I ran 93 in mine for about a week and a half before getting it tuned but I barely let it get in to boost just to be careful.
Silver WRX 420 is offline   Reply With Quote
Old 01-03-2005, 02:11 AM   #7
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Shouldn't the ecu have enough control to where it would be ok to drive into boost lightly?
DoctorNick is offline   Reply With Quote
Old 01-03-2005, 05:28 AM   #8
clamdip
Member#: 18709
i'm sure the ECU will pull timing if the motor starts to knock. so 93 octane is good. maybe a mix of 93 and 100 would be optimal.
clamdip is offline   Reply With Quote
Old 01-03-2005, 08:28 AM   #9
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
I find it amazing that the Octane rating is such a big deal Regular is about 92~93 in Japan. Now High Octane is a different story running about a 96~100 rating. Is there a difference between Japanese 93 Octane and American 93 Octane???
DuoMaxwell is offline   Reply With Quote
Old 01-03-2005, 04:00 PM   #10
dmross
Member#: 2818
2000 2.5RS
100 RON = 96.4 octane (PON)
dmross is offline   Reply With Quote
Old 01-03-2005, 07:17 PM   #11
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
I have been running mine on 92-93 for over 6 months--stock unflashed ECU. Started to get some knock, but put an alcohol injection system on it and it runs perfectly. BTW, 18.5 psi is stock for the version 7 ECU to run.
Kreeger is offline   Reply With Quote
ej207 swap into 03 wrx N8WRX Subaru Conversions 31 10-30-2008 09:56 PM
JDM V9 STi Swap into WRX ottawarex Subaru Conversions 12 10-29-2008 07:54 AM
JDM LGT Spec B swap into WRX, could using 91 instead of 96 be causing my misfires? wrxfactor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-23-2006 08:50 PM
JDM V7 swap into 2002 WRX, Will it pass NYS inspection?? jonepachek Subaru Conversions 1 08-20-2005 01:25 PM
WTB: WRX/JDM Turbo Swap into GD fukamoto Private 'Wanted' Classifieds 2 09-12-2003 02:59 PM
