Old 12-31-2004, 05:40 PM   #1
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Default Different color front crank seals
I can't find anything on this, so I thought I would pass it on.
I have replaced quite a few front crank seals (mostly 2.5 NA, some 2.2 NA) on Suby engines.
I sorta noticed some seals were brown, some were black. I have had to "warranty" some labor due to leaks. Talking to a local dealer parts guy, I learned this.
Some time ago, SOA issued a notice that the dealers were to ditch ALL their crank seals that were black (and no reimbursement) and restock with the brown seals only.
It seems the black ones were bad.
IIRC, all the leakers I have replaced (OEM install or re-replacement) have been the black ones.
In fact, I have a small leak I am resolving in my own rebuild (while replacing the water pump, but that's another story) that has a black seal in it.
It is getting a brown one now.
Old 01-02-2005, 11:47 AM   #2
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Post
I've replaced two black crank seals with the newer brown seals. What's the difference? Material, spring, size?
-Charles-
ImprezaVA is offline   Reply With Quote
Old 01-03-2005, 01:44 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
My guess is the material.
The PN on the seal is different as well.
I am not home, so I can't get the whole number, but the black ones end in "E" and the brown end in "G".
When I get home (in about 2 weeks) I can look up the whole PN on a seal site and see the description.
Old 01-03-2005, 01:57 AM   #4
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
All crank seals I've replaced have been brown ones. Never really noticed that they dropped the black ones.
-paK +1
Pakin is offline   Reply With Quote
Old 01-03-2005, 02:42 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Pakin, do you mean you have only put in brown seals, or only had bad brown seals??
Old 04-14-2012, 01:33 PM   #6
Ryanrugger
Member#: 234764
2000 2.5rs
Default Seal replacement.
I am getting ready to do my timing belt and was wondering if any of you can explain how to replace these seals while I'm in there. Pictures would be nice if you have time.
Ryanrugger is offline   Reply With Quote
2.2L Front Crank Seal Issues zferakid Normally Aspirated Powertrain 3 04-27-2008 01:32 AM
How bad is a leaky front crank seal or oil pump? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-04-2007 12:24 AM
Front crank seal leak RickV Service & Maintenance 4 04-30-2006 12:45 AM
Front crank seal on 1.8 L mh0384 Normally Aspirated Powertrain 2 07-21-2004 11:12 PM
Different Years different colors?? Frank General Forum Archive 2 03-06-2001 01:40 AM
