Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 07-07-2001, 01:14 PM   #1
josh
Guest
Member#:
Default Vishnu up-pipe install and review....
hey all,
last night i installed shivs new up-pipe. It took a while, but in the end it was well worth it. here is a little review.
the up-pipe;
omg. the thing is rediculously overbuilt. water cut everything, the welds are stunning (i know it is hard to use "stunning" to describe welds, but wait until you see them). basically they craftsmanship is superb. i am used to shiv and how he operates, and i would have expected nothing less. simply a very well built up-pipe.
the install;
the install was pretty tough. anyone who has changed their clutch or turbo before will have no trouble. if you havent really torn apart a turbo car, then i recommend a professional install this for you. i will be writting up the entire install step by step, so not too much detail in ths post. here is a quick overview;
1. remove downpipe
2. remove heat sheild from header (involved dremeling, or removal of o2 sensor)
3. loosen right hand header
4. completely unbolt turbo, i left the oil lines on.
5. unplug the EGT sensor.
6. lots of manipulation, but the up pipe came out up throught the engine compartment.
7. install the new uppipe
8. do everything in reverse (much faster)
that is a *brief* overview. it isnt that any one thing is very difficult, it is just there are so many things you need to be careful about. but the reward is well worth it...
one test drive later...
wow. i didnt really know what to expect performance wise from the up-pipe. well, i was pleasantly rewarded with much faster spool up, and more power throughout the rpm range. what was also very noticable, and a huge plus, is the off boost performance increased signifigantly. cool. less lag, much faster spool up, and a bit more power. for the $$, I am very very pleased. my mods are listed below if you are curious what else i have done to the car.
i talked to shiv a bit about this last night, and he also told me that my EGT's dropped as well. Imprezer's EGT's droped up to 200 degrees in certain situations. it makes sense. there is no more "heat soaker" (the cat) pre warming the car for you anymore. shiv will explain it better, but the benefits of this up-pipe are numerous.
if you have questions, please let me know. I DO NOT know the price so dont ask me how much it is. direct all those questions to shiv. but if you have questions about the uppipe. let me or shiv know. I do not work for Vishnu, or shiv, just one of the lucky bastards who lived 15 minutes from him thanks shiv!
josh
2002 WRX wagon
Apexi catless exhaust, Vishnu performance up-pipe, Greddy type-s BOV, Greddy Profec B boost EBC (low boost=12.5, hi=13.5-14), Greddy boost guage, K&N panel filter, KYB agx's. tein forester medium s-tech springs, 99 RS wheels w/ 008r tires (225/50/16), 20mm rear sway bar, tinted.
Old 07-07-2001, 02:38 PM   #2
jmott
Member#: 6713
2007 Prius
brown
who do I call to order one?
jmott is offline   Reply With Quote
Old 07-07-2001, 03:40 PM   #3
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
How long did the whole install take? You are running a CEL because of your catless exhaust, right? Would running just the up-pipe cause a CEL?
illmatic is offline   Reply With Quote
Old 07-07-2001, 03:43 PM   #4
iceweazel
Member#: 6816
01 yeller wrx
triumph tiger,klr,cb900f
Josh, does this mean shiv has the new batch and is
ready to ship soon? (already ordered mine^_^)
iw
iceweazel is offline   Reply With Quote
Old 07-07-2001, 04:23 PM   #5
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Hey SHIV - - I sent my check some time ago - does this mean I should expect the unit soon? Best regards - AL
alfriedesq is offline   Reply With Quote
Old 07-07-2001, 04:45 PM   #6
shiv
Member#: 607
Hiya guys,
Check out the Vendor forum for more info on the up-pipes.
http://www.i-club.com/forums/showthr...referrerid=607
Quick overview: Now that I know it fits well, production started this morning. Should have the first dozen or so up-pipes ready for shipping on Monday or Tuesday. Another batch to follow a couple days after that. And after that. And so on. Supply will not be a problem.
Cheers,
shiv
shiv is offline   Reply With Quote
Old 07-07-2001, 06:02 PM   #7
josh
Guest
Member#:
in order...
jmott- see shivs post.
illmatic- funny you should ask about CEL's. i have been getting them, but lately, they are going away. every now and then i will throw one, then then next time i start it up, its gone. i had one before the install, and it was there when i first started the car after the install. i drove about 15 miles, and when i started the car back up, the CEL was gone. go figure. i will keep you posted tho if i throw another.
it took about 5 hours total, w/ dinner break, and tending to a pregnant wife.
no i did not get the uppipe to get rid of the CEL. i dont care if the ar throws a CEL.
and for obvious reasons, yes I was the beta tester for the final production test. as shiv said, they are in production right now.
josh
Old 07-07-2001, 06:41 PM   #8
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Cool cool cool!
To make the installation easier, I removed the engine mounts botls and jacked up the engine a tad to allow more room to wiggle the uppipes in and out.
Yeah, the EGT's will drop. I guarantee. They did on my car and now my EGT's never, eeeeeeeeeeeeeeeeeeever go above 1550 even under the most extreme conditions.
Also, the uppipe saves you some weight over the fatty stock one.
What else, hmm, yeah, hmm, use anti-seaze (sp?) on all exhaust and turbo bolts. You will thank me for that later.
Imprezer is offline   Reply With Quote
Old 07-08-2001, 04:24 PM   #9
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Shiv - going into production over the weekend - YOU ARE THE MAN - who else is so dedicated to our addiction - thank you man - PS - I emailed you!1
Old 07-08-2001, 07:12 PM   #10
shiv
Member#: 607
Cool
I'm not the man yet. First I want to see all these pipes going into WRX without any hitches
If all goes well with this product, I'll be offering more in the near future.
Cheers,
shiv
Old 07-18-2001, 11:16 AM   #11
harrydog
Member#: 3773
2002 WRX Sedan
2006 Outback 3.0R
This sounds like a must-have mod to me.
So far my car is stock and I'll be doing my modifications one at a time with the up-pipe being the first, I think.
I'm looking for someone in the Cincinnati area who I could use to do this type of work. Anyone have any recommendations?
harrydog is offline   Reply With Quote
Old 07-19-2001, 05:48 PM   #12
iceweazel
Member#: 6816
01 yeller wrx
Question
josh: )5. unplug the EGT sensor. ->stock or you added?
harry: Couple places I know in Columbus, but none in cincy.
Doing my own here soon if you care.
iw
Old 09-18-2001, 03:46 AM   #13
100
Member#: 10034
2002 WRX Wagon
WR Blue. niiiice.
Bump!
Yeah, what about that stock EGT probe? Do you save it or order a new one? Isn't it welded in?
PEACE
OUT
100 is offline   Reply With Quote
Old 09-18-2001, 04:00 AM   #14
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
josh, do you have a good pic of your car.(from the side would be even better) I would like to know more about your suspenion. I was thinking about the tein's but I wasnt sure what struts to go with. Any input would be great!
thanks
-nick
Redline8k is offline   Reply With Quote
Old 09-18-2001, 10:12 AM   #15
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
You remove the stock from the old cat, and put it into the new up-pipe. No it is not welded in. I didn't have to remove any mounts (have air tools). It did take like 6hrs though.
Ken
DeliciouSpeed is offline   Reply With Quote
Vishnu Crank Pulley, Install and Review Hotrodguru Texas Impreza Club Forum -- TXIC 7 01-20-2004 01:57 PM
vishnu up-pipe install review IronChefWRX Tri-State Area Forum 17 08-02-2002 10:07 AM
Vishnu Up-pipe Install (need shop) sliver Southern California Impreza Club Forum -- SCIC 6 01-18-2002 11:47 PM
One-off up-pipe installed and working! ascott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-13-2001 12:07 AM
Vishnu Up-Pipe Install Scoob Mid West Subaru Owners Club Forum -- MWSOC 23 09-17-2001 12:44 PM
