Old 12-31-2004, 09:15 PM   #1
chrisj
Member#: 582
1999 Impreza RS
Default Utec on JDM swaps
Has anyone used a programable ECU link on a JDM swap?
chrisj is offline   Reply With Quote
Old 12-31-2004, 11:26 PM   #2
manchild83
Member#: 55554
2008 GTi
Candy White
Talk to George user name sonicyellowrx he did a JDM sti engine swap and is running a utec on it.
manchild83 is offline   Reply With Quote
Old 01-01-2005, 02:44 AM   #3
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
i have a utec i purchased in the summer and still have yet to put it on yet, reason being theres no twinscroll base map and i dont want to put it on untill i can get it tuned.
ImprezaRSfan! is offline   Reply With Quote
Old 01-01-2005, 08:42 AM   #4
chrisj
Member#: 582
1999 Impreza RS
Well I'm going to do a swap in within the next 6 months so I'm trying to figure out my game plan. The stock STI is great, but with the upgraded turbos and such that I plan on doing I'm going to want the most out of the engine.
Are there any other programable ECUs that can be used?
Old 01-01-2005, 11:25 AM   #5
chrisj
Member#: 582
1999 Impreza RS
SO let me ask this... IF I have every intent to build up the base STI engine then should I look at a Ver.8 or somthing? I'm just not all THAT sold on twinscroll and the prices that they get for them are nuts. Now if there is a tuneability factor involved then I'll look at a newer setup.
Old 01-01-2005, 11:34 AM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
You can use the UTEC with a JDM ECU, I used one for a little while before I had the ECU reflashed. You need a JDM ECU specific version or else it'll throw 4 injector codes. They don't affect anything performance wise but the JDM version will get rid of the codes.
To put it simply, whatever methods are available for the US WRX are available for the JDM ECU. If you want to use AVCS though, you need to use something that piggybacks off the JDM ECU or supports AVCS like the Hydra or Motec.
Old 01-01-2005, 11:44 AM   #7
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
The AUS UTec will work with JDM ECU. ECUTek reflashes work as well. MoTec, GEMS, and Hydra works and controls AVCS.
MoTec has anitlag built in as well.
Need4Boost is offline   Reply With Quote
Old 01-01-2005, 11:57 AM   #8
chrisj
Member#: 582
1999 Impreza RS
Yeah thats the type of stuff I am looking for. A buddy has a DSM link on his eclipse and I love it. He can go down the road with a laptop and tune as he goes. It has the antilag and all that good stuff too. So sounds like Motec might be the better solution... but yes, I did want to use the AVCS and possibly even the DCCD if the tranny I get happnes to have it.
Old 01-01-2005, 12:03 PM   #9
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I _think_ the PnP version of the Link finally supports AVCS but I'm not sure. The Motec is much more expensive.
Old 01-03-2005, 01:17 PM   #10
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I think rev6b won't give you a CEL, but I'm not sure. It definately will work though.
garface is offline   Reply With Quote
Old 01-03-2005, 02:00 PM   #11
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
Revision 6 and up will works as they do have the wiring for AVCS, but they will still throw injector codes. I have the JDM/AUS utec and have never had any codes.
George
SonicYelloWRX is offline   Reply With Quote
UTEC on JDM V7 blueribbon UTEC 3 11-10-2006 06:20 PM
UTEC on JDM ECU thechase Engine Management & Tuning 15 10-10-2005 11:06 AM
rev 6 utec on jdm ecu ImprezaRSfan! Engine Management & Tuning 3 11-02-2004 05:37 PM
rev6 utec on jdm ecu ImprezaRSfan! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-02-2004 04:05 PM
utec on jdm motor phatroksek Engine Management & Tuning 6 01-06-2004 10:01 AM
