Old 01-01-2005, 07:45 AM   #1
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Default Use good oil with JDM engines OR pay the price!
I was lucky enough to see something this last weekend (one prior to New Years) that will make you think twice when its time to change your Oil. I got to visit with a Subaru Master Tech at a Subaru dealership in Hachinohe. He said that Subarus have very tight tolerances between the pistons and cylinder walls (of course). He went on to say if you put cheap oil in your engine and by cheap I mean some crap oil you can destroy your engine you will regret it. His example a 2004 STi engine set-up with some cheap crappy oil in it. He revved the engine to 3k RPM and held it there for approx. 2 mins and BANG and I do mean bang. He said the tight tolerances between the cylinder walls and pistons will break down crappy oil real quick. When it was all said and done=
1xRod broken
1xhole in block
1xpiston destroyed
I just thought I would tell you guys now if you believe it or not is up to you. I am sure most of us do not run crappy oil in our beast. Just a little thought next oil change and your wanting to save a few bucks.
Oh and they are not saying buy the most expensive crap on the market they are just saying use a good well known reliable oil!!!
~Mike
DuoMaxwell is offline   Reply With Quote
Old 01-01-2005, 07:14 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
What are the standards of oils you are talking about here? Even the crappiest or cheapest oils here in the US pass certain SAE standards........
You have to be at least slightly specific if you want to warn people about something.
Also, if Subaru has such tight clearances....why all the piston slap?
Jay Storm
Old 01-01-2005, 07:50 PM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
this post was kind of useless
YaZahX is offline   Reply With Quote
Old 01-02-2005, 01:19 AM   #4
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
I am glad you think so YaZahz but I was trying to be helpful.
Storm I dunno what he means by cheap oil because I run mobil 1 but I assume it would be the $2 a case type crap they are referring to.
Amazingly enough I run 5W-50 and I have no piston slap in the morning when its sub 0 degrees outside. On newer engines the tolerances are different compared to the older EJ20Gs. I just posted this but I should have said something to the fact of extended hard run. Sorry if you feel this is pointless but I just thought I would let you guys know.
Old 01-02-2005, 01:36 AM   #5
jamesfacts
Member#: 51282
98 RS
black & blue from parking
My school of thought (and I've heard plenty of people echo this) is that you should buy inexpensive dino oil and change it frequently, rather than buy expensive synth stuff like Mobil 1 and change it less often.
jamesfacts is offline   Reply With Quote
Old 01-02-2005, 12:46 PM   #6
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
I've blown up one engine on my Subaru and one engine in my racecar as a result of using synthetic oil. I refuse to run it anymore. Oil needs to be changed regularly, if for some reason you are running synthetic oil and changing it every 3k miles you are pissing away money.
Z
Zephyr is offline   Reply With Quote
Old 01-03-2005, 12:57 AM   #7
dentprone
Member#: 18588
1999 busted car
silverthorn
piston to cylinder bore clearance is 0.0004-0.0012 of an inch on most of the subaru engines...tiiiiiggghhhhtttt!
dentprone is offline   Reply With Quote
Old 01-03-2005, 01:08 PM   #8
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Why would he purposely blow up the engine? Wouldn't it blow up when driving at a constant RPM also? I don't get it.
garface is offline   Reply With Quote
Old 01-03-2005, 09:43 PM   #9
TheWicked
Member#: 78258
sounds fishy to me..
TheWicked is offline   Reply With Quote
Old 01-03-2005, 10:23 PM   #10
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
To prove a point. It sounds like a dealer demo, engine not in car. It would blow up when driving at a constant RPM, but my motor can cruise at 3800rpm for hours on end (highway driving).
<-- (uses mobil 1 full synth because T-rex's are big & scary).
tooocool49723 is offline   Reply With Quote
Old 01-04-2005, 12:00 AM   #11
supermarkus
Member#: 6971
2008 WRX STi
SSM
I forgot to hook my fan up after a radiator swap on my Jeep once and even after getting all of the air out of the system, that sucker ran hot instantly with no airflow to the radiator. And that was just at idle. I'd hate to see someone do the same on a turbocharged car, I can imagine the engine popping rather quickly in that case, especially with crappy oil.
supermarkus is offline   Reply With Quote
Old 01-04-2005, 05:05 PM   #12
Bottom Feeder
Member#: 2808
So he blew an STi engine just to prove his point to you? I call B.S.
There is nothing special about how Subaru builds it's engines. Every modern engine has pretty tight tolerances. Even cheap oil has to conform to certain 'good enough' quality specs that will work in a Subaru. Although cheap stuff won't hold up long under heavy abuse (which will only cause excess wear), the only way you'll kill an engine running at a leisurely pace like 3k RPM for two minutes is if there's no oil in it at all.
Bottom Feeder is offline   Reply With Quote
Old 01-04-2005, 05:14 PM   #13
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
Uhm.... why was he just sitting there, holding the RPMS at 3K for 2 minutes???
I dont believe this one bit, and if it DID happen, it wasn't the oil that did it...
WRXGuyInUSA is offline   Reply With Quote
Old 01-04-2005, 05:37 PM   #14
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
again, I laugh at a response like this.
It appears as if many people have never driven on the highway. 5th gear, 75mph is about 3600rpm. and being on the highway, it's probably going to be held there for a while (couple hours).
I call B.S. on all the people who cant see why anyone would hold an engine at 3,000 rpm for 2 mins.
However, again, without proper cooling (more than just the stock fans at 0mph), combined with crap oil, and a badly treated motor, it'll blow fairly easily.
Old 01-04-2005, 06:25 PM   #15
dentprone
Member#: 18588
1999 busted car
silverthorn
maybe the sti was a car brought in to the dealer with an engine noise...which was most likely caused by a irresponsible owner overboosting his brand new engine without the supporting mods usually associated with raising the boost...and maybe the guy was using crappy oil as well...who knows...there is no need to get upset about this post...most of the crap that is typed on the internet has to be taken with a grain of salt.... if you dont know that engines need good oil,and changed often.... you will be paying for a new one sooner then you would like
Old 01-04-2005, 06:37 PM   #16
Bottom Feeder
Member#: 2808
Huh? I think you're missing the point. Nobody's saying that running an engine at 3k for a few minutes is abusive in the least... and that's the problem. I think the doubters (like me) have a hard time believing that that would cause a motor to blow. Follow?
Old 01-04-2005, 07:10 PM   #17
AKGC8
Member#: 1305
2000 Impreza
BS.
He wasn't by chance trying to talk you into paying extra for synthetic oil when you took the car in for an oil change was he.
There are a lot of techs who actually don't know much about aftermarket parts and tuning. That won't stop them from talking like they do though. Not that oil really has anything to do with that, just saying some techs like to tell bs stories.
AKGC8 is offline   Reply With Quote
Old 01-04-2005, 09:10 PM   #18
caryfd227
Member#: 22512
2015 Subaru WRX
Galaxy Blue Pearl
BS
caryfd227 is offline   Reply With Quote
Old 01-05-2005, 04:15 AM   #19
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
ROFLMFAO
OK now I tried to be serious and tell you what I saw and what was explained to me. Now I don't go to Subaru for my oil change and I don't use the $150 STI 3L can of oil either. The point he was trying to make was using a crappy oil that is extremely cheap with these engines is not a good idea. Now if you would like to continue to call bs thats fine. I really don't care. I was not the only one there I was brought as a guest with Naramasa Speed. There were several tuners and technitions there to show what things can cause this engine to take a crap!!!! This being one of the big problems with the Japanese people that buys these cars and run them hard!!!
Mods if you dont mind please delete this thread as there are to many people who think they know everything there is to know about the EJ series engines!!!
Old 01-05-2005, 01:02 PM   #20
Bottom Feeder
Member#: 2808
Like you?
Old 01-05-2005, 02:50 PM   #21
Sperm
Member#: 25038
2002 PSM WRX sedan
I appreciate the info, Duo.
If you think it's BS, just read it, click the little X in the top right corner, and go about your day.
Sperm is offline   Reply With Quote
Old 01-05-2005, 03:03 PM   #22
garface
Member#: 1581
MY00 RS/STi7
Well, if you weren't there alone and it was some sort of display then it makes a lot more sense. I was picturing this guy blowing up an engine to prove a point to just you. Unless you were a Subaru engineer I couldn't imagine someone doin that. Makes a lot more sense now.
Old 01-05-2005, 03:22 PM   #23
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
I share that thought.. I mean usually when your engine gonna do a little breakage... would think it would give abit more hrm...warning...correct me if I'm wrong but a rod breaking at 3k RPM assuming it is already well lubed is puzzling... hell I hit the rev limit on my care once becuase a person cut 3 lanes right in front of me and hit the breaks and in my rush to shift to a lower gear to go around I held the gas with clutch disengaged * that person got a the glare!
but I didn't break anything... I mean the needle was jumping on my car with engine cutting ... I was like *oly *hit now I keep the safe space from that mark
Kcwiro is offline   Reply With Quote
Old 01-05-2005, 04:55 PM   #24
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
theres a difference between freewheeling the motor and putting it against load
Old 01-05-2005, 05:37 PM   #25
Porter
Member#: 486
2004 Forester XT
bug spattered
I'd like to chime in here....
This story is total BS.
Up until last week I was driving my SVX around in 1st and 2nd gear due to my trans losing 3rd and 4th...
I didn't realize I was consuming a great deal of oil due to a stuck PCV and I was making repeated (30+ in a row twice a day) runs to 6500 rpm in order to maintain 80mph... this was for the better part of a week while THREE QUARTS LOW ON OIL.
The motor is fine, runs like a champ. I topped it off with CHEAP convenience store brand 10W40 and it's happy as a clam.
There is NO WAY to blow up an STi motor at 3k RPM as a result of the TYPE OF OIL.
That is pure fantasy, and that guy should lose his job if he told you such utter nonsense.
Porter is offline   Reply With Quote
When infants pay the price/Fallujah in pictures Chewyguru Political Playground 49 08-02-2010 12:52 AM
BD JDM Fogs, Used but mint with JDM switch $130 Shipped MacSti Legacy Specific Parts 6 10-09-2009 03:32 PM
1998 2.5rs coupe with JDM engine for sale or part out yuboyus Private Vehicle 'For Sale' Classifieds 129 11-12-2008 03:32 AM
Pay the bank or pay the tuner? Dave D. Newbies & FAQs 18 11-06-2006 04:57 PM
JDM engine or race motor? STI-Spec Subaru Conversions 20 10-25-2004 01:21 PM
