Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 01-01-2005, 02:23 PM   #1
SOLUTION
Member#: 43602
2005 Outback Sport
Default Idle Hunting and Engine Boging
I'm having some frustrating problems with my car - here is a link a discussion of the problem: http://www.wrxforum.com/cgi-bin/ulti...c;f=4;t=001418
Any suggestions?
SOLUTION is offline   Reply With Quote
Old 01-01-2005, 07:22 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Clean/replace the IAC...
Old 01-02-2005, 05:18 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
If you noticed, he replaced the IAC on 12/29.
As to a suggestion, it could be many things.
Old 01-02-2005, 09:41 AM   #4
z&cobb
Member#: 12344
2002 2JC
blue
There are few facts. That's a chance to be creative.
At least it can't be due to automatic transmission failure.
z&cobb is offline   Reply With Quote
Old 01-11-2005, 08:36 PM   #5
SOLUTION
Member#: 43602
2005 Outback Sport
I recently bought a scantool from scantool.net - it can display realtime data from the sensors to a laptop. The voltage readings for the front 02 sensor were all over the place and the car - according to the scan tool- went back and forth a few times from open loop to closed loop and finaly just stayed in "open loop, driving" The voltage reading for the front o2 sensor ended up being 7.995 at that point, where as before it would bounce around, end up at 7.995 for a bit and then bounce around more. Other than a bad o2 sensor - I replaced it a while ago - what could cause the readings to be so messed up?
Oh, and the CEL for p0130 - front o2 sensor circuit malfunction - is on.
Old 01-11-2005, 09:11 PM   #6
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I'd suggest you swap with a buddy and see if that fixes it. The front O2 sensor is real pricey, so I'd check first before buying.
Old 01-14-2005, 03:41 PM   #7
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Originally Posted by SOLUTION
The voltage reading for the front o2 sensor ended up being 7.995 at that point...
7.995V? In relation to the ground? That's really, really wrong. Narrowband sensors should never read more than 1V and widebands (the kind WRX's have) should never read more than 5V. 7.995V is wrong. That guy is b0rk3d hardcore.
Al_Smokemcrack is offline   Reply With Quote
Lean condition...idle hunt rxer311 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 02-07-2009 12:31 AM
Idle hunts,Vac leak or other problems? mxpunk Normally Aspirated with bolt-on Forced Induction Powertrain 15 05-27-2008 08:59 PM
cruise light, idle hunt, and choppy mid throttle rodder UTEC 5 04-15-2008 11:24 AM
Idle hunting issue? dexterous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 11-29-2006 01:24 AM
Idle hunting - up/down west_minist Service & Maintenance 11 12-28-2005 10:17 PM
