Old 01-01-2005, 09:31 PM   #1
Extra300
Member#: 77735
Default STI Hood Scoop vs. WRX Hood Scoop
Have an 05 WRX, looking to do a TXS UTEC stage 2 soon and wanted to know if there would be any advantage or disadvantage of using the bigger scoop with the stock intercooler?
Thanks.....
Extra300 is offline   Reply With Quote
Old 01-01-2005, 09:34 PM   #2
pityr
Member#: 31719
Yes, but you would need the splitter to make it effective.
do a search...
pityr is offline   Reply With Quote
Old 01-01-2005, 09:54 PM   #3
imprezavness
Member#: 59563
2004 white WRX
confused
bigger splitters need to be matched to bigger intercoolers not bigger hood scoops
imprezavness is offline   Reply With Quote
Old 01-01-2005, 10:55 PM   #4
Extra300
Member#: 77735
So would i need to use a bigger splitter if i was to stay with the stock intercooler or could i just use the standard one?
Old 01-01-2005, 11:01 PM   #5
HoOn
Member#: 43270
2004 Impreza WRX
I have the STi hood scoop with the Sti Air Splitters and they work fine.
- John
HoOn is offline   Reply With Quote
Old 01-01-2005, 11:05 PM   #6
emnm79
Member#: 76909
i thought the sti splitter was larger, ie: too big for wrx intercooler and allows air to flow around it..
emnm79 is offline   Reply With Quote
Old 01-01-2005, 11:27 PM   #7
Lachlan
Member#: 19470
1981 Brat GL
Have you seen the area that the gasket actually surrounds? It doesn't skirt the edge of the intercooler as one might expect--it just encloses a smaller area within the face of the intercooler, so the STi splitter should still fit nicely onto the wrx intercooler.
Lachlan is offline   Reply With Quote
Old 01-02-2005, 01:44 AM   #8
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
you can stick with yours and do a search on ebay for a splitter, I think the guy sells them for like 30 or something. or fashion your own with a thin sheet of metal and some tin snips.
Old 01-02-2005, 09:42 AM   #9
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
If you are using the stock ic, keep the stock seal/splitter. The scoop doesn't matter. You wan to seal the ic to the bottom of the hood. The scoop is sealed to the top of the hood. it is more important to seal the hood to the ic, then to seal the scoop to the splitter.
Russ
WRX1 is offline   Reply With Quote
STI hood scoop and WRX hood IMPEZER22 Private 'Wanted' Classifieds 0 07-02-2009 09:32 PM
V7 STI hood scoop splitter, WRX hood scoop & splitter, fog lamps and more gling Exterior/Styling 14 06-29-2008 12:34 PM
STI hood scoop Vs. WRX scoop anderszway Newbies & FAQs 29 03-17-2007 12:08 AM
WTT in NC: Want STI Hood Scoop/Have WRX Hood Scoop jason6787 Private 'Wanted' Classifieds 15 02-06-2007 11:40 AM
Fs: 04 Sti Hood Scoop And Wrx Hood Scoop pabloherrera Private 'For Sale' Classifieds 0 05-19-2006 04:07 AM
