Old 01-02-2005, 03:52 PM   #1
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Default Which spark plug for these engines?
Hi guys,
I have read the FAQ on plugs and still can't get a solid answer. I have a question for 2 cars.
My wife has a STAGE 2 2005 Legacy GT. Would a colder plug be a good idea? If so which one? Part #s? Iridium? And what do I need to gap it too?
I have a STAGE 2 2005 STi. Would a colder plug be a good idea? If so which one? Part #s? Iridium? And what do I need to gap it too?
Like I said I've searched and could not get a solid answer especially on colder vs. stock.
Thank you!
Old 01-02-2005, 07:10 PM   #2
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Stock temp for both. Stock gap for both. Plat for long change intervals, copper for shorter change intervals, just say no to iridium.
Old 01-02-2005, 10:38 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Ron....the stock plugs for the EJ257/EJ255 are iridium and iridium is a MUCH better conductor than platnium.
I have had IK-22's in my car for a LONG time without any issue.
Old 01-02-2005, 10:40 PM   #4
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
I thought also that if you had Stage 2 or more that you wanted a colder plug. Is this true?
Old 01-02-2005, 10:41 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
....only if you are using a good bit more boost.
I run up to 22psi or so...
Old 01-03-2005, 12:05 AM   #6
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
My favorite Uncle....while you are technically correct, I must disagree.
Iridium plugs are more expensive and add zero HP.
Platinum plugs are cheaper and add zero HP.
To each his own, but I'm from the Team Food Stamps Racing crew.
Old 01-03-2005, 12:11 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
...actually....an iridium plug, that is electrically a better conductor, will yeild a better spark...and iridium is harder and has a higher melting point than platnium and therefore should last longer......soooooo....60k mile plugs or 90k mile plugs....you pick
Old 01-03-2005, 12:14 AM   #8
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Don't forget that plugs like to become one with the head if you leave them in too long.
OneOBS is offline   Reply With Quote
Old 01-03-2005, 12:29 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
...nothing a bab of the correct anti-seize won't make that issue an issue....
Which spark plugs for Hybrid motor? orion3 Built Motor Discussion 10 08-22-2008 06:00 PM
Which Spark Plugs for a JDM Engine? DScamp Service & Maintenance 6 02-10-2008 11:18 PM
Which Engine Oil and Spark Plugs for the TRACK ??? george3 Motorsports 25 01-10-2008 09:59 AM
Which spark plugs for my COBB Stage 2 '04 STi? AlxSti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 12-05-2006 07:22 PM
which spark plugs for tuning? carbonrex1 Engine Management & Tuning 3 08-03-2005 09:03 AM
