#1 |
Member#: 67127
Vehicle:3.3 I <3/h8 my GF3 1.8-2.5-2.2-2.5-2.2-3.3 |
Ok, i'm getting a set of Hella 500's (driving pattern) in a week or so, and want to increase the output of the stock Fog lights. I was looking at rallylights.com's Yellow Star H3 bulbs (i'm 90% sure that their H3's that I need, if not someone correct me). I noticed that they had 3 wattages listed, 55w (stock) 85w, and 110w. I was wondering, since i've got a few relays sitting around, and am going to be upgrading the factory wiring harness anyway, how high of a wattage could I go and still not burn the stock glass/plastic in the fog lights?
I'm also going to be getting some Osram Silverstars for the stock headlights (but this is more of a than relavent to the thread)Thanks.
#2 |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
i ran my hella 500's with 100W bulbs with no problems at all.....and yes it is H3
#3 |
Member#: 31511
SCIC
Vehicle:03 GD2 95 GM4 www.ITNRally.org |
I ran the Hella 500s with 160w bulbs with no problems. If you have the Lexan covers turn the lights off when you aren't moving
#4 |
Member#: 67127
Ok, I obviously didn't explain well enough. I'm getting Hella's, but I want to upgrade my STOCK RS fog lights. I dont even have the Hella's yet, and i'm sure they'll do well (or at least i'll decide what to do once I get them).
I just want to know how much the subaru, stock RS fog lights can handle before they start to burn. (thanks for the quick replys though) |
#5 |
Member#: 31511
SCIC
oOooOooo
Not sure what the bulbs are, but you may want to go a head and make a new relay harness. The stock wiring may not handle much more the 60-80 watts. The plastic lens may not survive more than 100w. ![]() good luck ![]() |
#6 | |
Member#: 4597
TXIC
plastic lens - rapid_roo? the fogs are glass....at least they were in my GC and the 02-03 i have seen.... ![]() |
#7 |
Member#: 67127
Meh, dont care about that, it's already discolored yellow.
Guess i'm going to have to use those relays... |
#8 | |
Member#: 31511
SCIC
( I could be wrong, I am too lazy to actually look at them now... its to wet and cold out there ) |
#9 |
Member#: 4597
TXIC
well having gone through about 3 sets of stock fogs on the GC i can promise you they are glass...
#10 |
Member#: 31511
SCIC
I stand corrected. They sure looked plastic
I still haven't decided what to do with them. I am not sure if the wiring is even intact, I know that the bulbs are all missing and they like to hold water. ![]() oh well its the daily driver, so I am not going to worry about it too much. What I need to do is finish the lights on my WRX ![]() |
#11 |
Member#: 67127
/\ does your 95LX have an RS bumper/fogs?
I thought those had the little projector ones. I assure you however, the RS fogs are made of glass, and do break easily when subjected to road debris (rocks). |
#12 |
Member#: 31511
SCIC
mine look like these
![]() I tapped on them earlier this evening and they do feel like glass. I had assumed they were plastic because they looked so fogged over and glazed, and cracked like weathered plastic. if the harnesses and sockets are still intact, I may just load them with some Narva Yellowstars. ![]() |
#13 | |
Member#: 4597
TXIC
#14 | |
Member#: 5887
BAIC
Vehicle:2002 GDAA 797 |
![]() I concur. The lens is not plastic iirc. |
#15 | ||
Member#: 31511
SCIC
Never had the chance to convert the lights over to them.Quote:
| Thread Tools | |
| Display Modes | |
| Yes, another thread about smelling fuel | TheMileHighWRX | Factory 2.0L Turbo Powertrain | 8 | 10-06-2007 03:29 PM |
| And another thread on wastegate flutter | snoboardr4life | Factory 2.0L Turbo Powertrain | 0 | 06-10-2005 02:06 AM |
| Good music download program: YES! ANOTHER THREAD LIKE THIS! | Nightwing | Off-Topic | 10 | 07-05-2004 10:15 PM |
| another thread on shifting in search of the smooth as butter shift!! | asbWRX04 | Transmission (AT/MT) & Driveline | 4 | 05-13-2004 01:36 PM |
| Yes, another thread about Tuner Transformation | Bottom Feeder | Off-Topic | 6 | 04-10-2004 03:09 PM |
