Old 01-02-2005, 07:14 PM   #1
Greg - LI
Member#: 42873
2007 Outback 2.5i 5M
Satin White Pearl
Question 01 RS - Coolant recall done, same problem again
Hey all,
About 10 months and 18,000 miles ago I had the coolant recall/service campaign performed on my 01 RS. It had been sucking air in to the cooling system causing the reservoir to overflow. Since then everything has been fine until recently when the same problem started occurring again. Has anyone else experienced this? I will call my dealer tomorrow but it seems to me that this time they will need to do the head gasket since the conditioner isn't solving the problem. Am I right? Anyone know first hand? TIA
Greg - LI is offline   Reply With Quote
Old 01-02-2005, 07:27 PM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
The headgasket is shot and the conditioner was just a bandaide. It worked for awhile.
OneOBS is offline   Reply With Quote
Old 01-04-2005, 06:19 PM   #3
Greg - LI
Member#: 42873
Satin White Pearl
Bump
Old 01-04-2005, 06:26 PM   #4
Charge
Member#: 3313
The conditioner is to prevent the problem from occuring. Sounds like it was done too late for yours. If failure has occurred, then they need to replace the headgasket, and they will again add the conditioner. Since you'll have the conditioner in from the new headgasket's first use, you shouldn't have any more trouble(hopefully).
Charge is offline   Reply With Quote
Old 01-04-2005, 06:56 PM   #5
Greg - LI
Member#: 42873
Satin White Pearl
Thanks guys. Has this happened to anyone else yet?
Old 01-06-2005, 08:52 AM   #6
tcmo
Member#: 12817
2013 Legacy 2.5i LTD
Yes. Our 1999 Forester had the coolant additive put in 10 months (6000 miles) ago. It started leaking again in Dec and the dealer replaced the head gaskets under warranty. After 2 weeks, no problems yet.
tcmo is offline   Reply With Quote
Old 01-06-2005, 08:36 PM   #7
Greg - LI
Member#: 42873
Satin White Pearl
tcmo,
Thanks for the reply. I expect to have the same experience at my dealer that you had at yours. Good luck with your new gaskets.
Greg
01 RS 4EAT into 93 Legacy - Problems? SSLegacyGT Transmission (AT/MT) & Driveline 3 02-08-2009 01:08 PM
Has there been a recall on coolant reservoir tank paint problem? txl146 Service & Maintenance 2 04-03-2006 07:33 AM
are aftermarket springs the same from 02 wrx to 01 rs? TheBaron862 Brakes, Steering & Suspension 1 05-11-2003 11:13 PM
Is a 99L(TS) muffler the same as an 99-01 RS muffler? popnGEAR Normally Aspirated Powertrain 3 01-18-2003 10:02 AM
is the shifter lever the same on the WRX as MY00-01 RS? joostin420 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-12-2001 08:33 AM
