Old 01-02-2005, 08:22 PM   #1
Carbine308
Member#: 59068
Chapter/Region: HIIC
2005 Impreza WRX STi
One Blue and one Black
Default Hella 500s: Can I splice them to the OEM fog light wires?
Some background:
There I was, minding my own business...I was driving cross country on I-10. We were moving with traffic at about 85 mph, a strip of separated semi tire flies out from the vehicle in front of me and **WHAMM** Contact is made with my pax side fog light taking my mesh foglight cover and the integral mounting harware for the fog light with it.
So the way I see it, I have two options:
1. Find a source for a new OEM R side fog light (and a price - anybody know of a source other than the dealership?), upgrade the bulb to 55W Narva Golds, and go with a 3M protective film.
-or-
2. Spring for the Hella 500 ambers with the protective film.
Which leads me to my real question: Can I splice the Hella 500s in using the OEM wiring and OEM switch?
What say ye men?
Carbine308 is offline   Reply With Quote
Old 01-02-2005, 08:26 PM   #2
rs6
Member#: 58759
Originally Posted by Carbine308
What say ye men?
I'd say you probably should put a relay in.
rs6 is offline   Reply With Quote
Old 01-02-2005, 08:31 PM   #3
Carbine308
Member#: 59068
But don't the OEM fog lights already have a relay that I could use?
Old 01-02-2005, 08:39 PM   #4
sevendhappy
Member#: 16283
Teh Car n00b!
G-Club represent!!!
I have my Amber Hella 500 fogs spliced into my OEM wiring/swich and it has worked perfectly for several months now. I believe the Hella 500s use the same voltage/wattage as the stock fog lights, which is why it's okay to do this w/o relays. This is just from my own experience though, so someone please correct me if I'm wrong.
sevendhappy is offline   Reply With Quote
Old 01-02-2005, 08:42 PM   #5
Carbine308
Member#: 59068
Ah, so the OEM foglights really don't have a relay?
So when you connected the wiring, you just clipped the wiring harnesses and joined the wires together then, is that right?
I certainly hope that your method is correct, I'd like to keep this operation tidy as possible by using existing OEM installed items.
Old 01-02-2005, 08:47 PM   #6
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
No, OEM fogs just use the switch and puny wiring. You should upgrade to a relay even if your still using everything else stock. It's fairly easy, it'll take you a half hour if you know absolutely nothing about wiring, and will yield better lighting.
A search should yield the proper how-to on using relays, if not post again and we'll find someone to post a write-up.
tooocool49723 is offline   Reply With Quote
Old 01-02-2005, 09:06 PM   #7
Carbine308
Member#: 59068
I'm certain I could do the wiring myself.
I just needed a push in the right direction here. I think I'm going to go with the Hellas, use their wiring and relay, and use the OEM switch.
Thanks for the advice.
Old 01-02-2005, 09:34 PM   #8
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
Besides...
$30 + for OEM foglight (from another nasioc member?, this is a low estimate)
$24 ($12/side) for bulbs
$20 + for yellow tint
$74+ for replacement
vs.
$64 for amber hellas (from your local advance auto parts). Plus you get the upgraded wiring with them.
Old 01-03-2005, 12:42 AM   #9
Carbine308
Member#: 59068
$64 for the amber Hellas (maybe I'll just buy online)
$33 for the WRX mounting brackets (probably from an online store, dunno yet)
$23 for acrylic stone shield
$120ish for the Hella package
I've got the wife talked into the Hellas anyway. From what I've seen, they're brighter than the OEM lights with the Narva Golds.
Besides...
vs.
Old 01-04-2005, 01:33 AM   #10
bheinz57
Member#: 37870
2012 ISM WRX
'07 FXT Sports
No need to change the wiring--55 watts is 55 watts which is both bulbs, stock or the 500's. Just splice into the old wiring like 90% of everyone else that has done it and you will be fine. I did it two years ago and no problems here. If you want to get technical, you could probably change your whole car's wiring and get better flow through everything, but would it be worth it? 55 watts is 55 watts. Brian
bheinz57 is offline   Reply With Quote
How to replace OEM fog light bulbs on 2006 WRX? AutoBahn Electrical & Lighting 4 07-30-2010 09:36 AM
WTB: OEM fog light (P.S.) or Hella 500 Fog Lights BeBop86 NWIC Private Classifieds 11 10-25-2009 02:15 AM
Oem Fog light Wiring?! Grr8dane Outback Forum 1 08-28-2006 03:01 PM
Is it hard to replace the OEM fog lights? balajc Interior & Exterior Modification 4 07-07-2003 11:07 AM
Which hella fog lights fit the the stock fog light area? advance Interior & Exterior Modification 2 06-26-2001 01:32 PM
