Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-03-2005, 01:21 AM   #1
MoonDougie
Member#: 75913
Question Spark Plugs"noob"
I am thinking of using some Nology Silverstone sparkplugs and was wondering if anyone has used them?
MoonDougie is offline   Reply With Quote
Old 01-03-2005, 02:24 AM   #2
MoonDougie
Member#: 75913
Any info????
Old 01-03-2005, 04:13 AM   #3
Oi8ur5.0
Member#: 28910
2013 REX
DARK GREY
Never heard of them.
1. What are you putting them into ?
2. Why are you going to stray from OEM ?.....
3. How did you find out about this brand ?
We can start their.
Gotta be careful with your plug applications. There is not alot of leeway that a plug maker can take in making sure the Subie specs are met.
Oi8ur5.0 is offline   Reply With Quote
Old 01-03-2005, 04:44 AM   #4
MoonDougie
Member#: 75913
Putting them into a 99 2.2L
Thought that they might be better
Found out through a friend and I have Nology plug wires.
As far as leeway is their any difference with a Subie and any other car or do are Subies a little finicky when it comes to Plugs
We can start their.
Old 01-03-2005, 07:54 PM   #5
Oi8ur5.0
Member#: 28910
2013 REX
DARK GREY
I'm not familiar with 2.2 NA applications....so someone else is going to have chime in. But yes...the boxxer motor can have different needs on plug specs. The distance the plug tip goes into the cylinder being the biggy. A manufacturer will sometime's have their plugs listed under OEM applications because maybe the thread, diameter and gap range are correct....but they will allow a shorter spec plug to be used. This may work...for awhile....but it won't run well down the road. This happened to me once with an NA forester.....and I was quite pissed to have done the work it takes to just get one plug out.....to find out that the auto parts joint gave me a plug that was shorter. They showed me the application chart from Champion.....that had it listed. But it sure as hell didn't match.
That's just my experience though.
Old 01-03-2005, 10:49 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I'd say screw anything that isn't specifically PN'd for your engine.
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 710 09-01-2016 11:53 AM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
96 brighton 1.8l impreza 1-2 spark 3-4 no spark WRXR1A10 Normally Aspirated Powertrain 6 12-28-2007 02:52 PM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
('93-'01) Will you get better performance if you get different spark plug?? IBO Impreza Forum 4 04-08-2001 12:10 AM
