Old 01-03-2005, 02:23 AM   #1
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Default Wiring diagram differnces
I have a Chilton with a full wiring diagram from the 90-94 2.2 Legacy but when I was identifying some of the wires from the plugs that go into the ECU I noticed that there are a couple of wires that are the right colors but there are in different locations i.e. i'll have 3 wires that need to be identified and among the 3 wires in the diagram and in the pin outs all three colors are there but they are mixed up between the 3 pin outs. in other words I have pin outs d5 is suppose to be blk/wht, d6 is suppose to be wht, and d12 is suppose to be blk. But d5 is blk, b6 is blk/wht, and d12 is wht. How can I figure out which reference is right. Should I go by color or location?
~Mike
pilfflip is offline   Reply With Quote
Old 01-03-2005, 10:27 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Legacy777 is offline   Reply With Quote
Old 01-03-2005, 08:53 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What are you wiring in?
And Subaru changed wire colors from year to year without changing pin locations. Unless you have an FSM with the exact year of your car, you are going to see discrepancies on a Chiltons guide as their colors are often based on a single year...
though I shouldn't help you since you blew me off and never even had the courtesy to tell me you weren't gonna buy my heads...
Old 01-16-2005, 02:26 AM   #4
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
matt monson
sorry matt, I'm wiring in an ej22 into an EA dual range tranny in an '86 carbuerated EA82. I have the wires coming from the ECU all marked according to the chilton I have (with the 3 exceptions), but you guys are saying, trust the location more than the color?
And no, my wiring diagrams don't look anything like that. They are more of a physical lay out of where the wires go with a key on the pics to signify what they go to. I didn't take a long look at the URL's so I don't know if they are the same by the means of what they say goes where so I will check that out and compare them to the chilton.
~Mike
Old 01-16-2005, 02:29 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
The Chiltons diagrams aren't the most accurate. I second the idea of trusting a FSM diagram over Chiltons.
Jay Storm
Old 01-16-2005, 02:54 PM   #6
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
I donít even think the tech Subaru documents are 100% accurate. Iíve found a number of minor errors with these docs, mostly related to connector pins incorrectly referenced. Although I donít believe Iíve ever encountered an actual color difference which could really throw you off.
xcntrk75 is offline   Reply With Quote
$$$ Reward - JDM STI ecu pin diagram and engine wiring diagram- OK $250.00 cash ! alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 01-20-2010 10:49 AM
wiring diagram?/color of acc wire for radio boardCrazy Car Audio, Video & Security 5 04-12-2008 02:32 PM
2002 Accessport wires diagram ? (I have lose wires in the cable) peeledback7777 AccessPort 0 10-26-2006 10:48 PM
Looking for JDM V7 wiring diagram and '01 RS wiring diagram moss Subaru Conversions 1 07-06-2006 11:52 PM
('93-'01) Head light wiring diagram? STiShawn Impreza Forum 4 04-20-2001 02:58 PM
