Old 01-03-2005, 02:23 AM   #1
joe r
Member#: 53412
2003 Outback
Black and Gold.
Default EDM leveling question,please help?
I have searched all the post's I could find about wiring my edm headlights so that I can level them from inside the car.
My question is my plug on the back of my lights for the motors on both lights is a 6 pin plug,from what I read the edm's should be a 4 pin plug,why is it 6 pins on mine?
Yes they are true edm as they have the DOT stamp & the light output is to the right _//_//.
Please if you have wired these up help,lol
I need to know what switch to order & how to wire them.
Thanksfor your time.
joe r
joe r is offline   Reply With Quote
Old 01-03-2005, 03:03 AM   #2
sevendhappy
Member#: 16283
Teh Car n00b!
G-Club represent!!!
The EDM sti lights require the 6-pin levelling switch. CC-b sells them. http://www.cc-b.com/Merchant2/mercha...gory_Code=SI02
sevendhappy is offline   Reply With Quote
Old 01-03-2005, 09:19 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Hmm....this is very interesting. The EDM lights for my legacy have the 6 pins as well. Anyone have a diagram for these 6 pin sti EDM lights?
TIA
Legacy777 is offline   Reply With Quote
Old 01-03-2005, 10:00 AM   #4
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
FWIW, my JDM projectors have the "DOT" marking on the lenses as well. Both do.
Like seven said, EDMs use the six pin setup.
02R6 is offline   Reply With Quote
Old 01-03-2005, 09:12 PM   #5
Legacy777
Member#: 4800
come on, someone's got to have a diagram for the EDM leveler system...
Old 01-03-2005, 09:14 PM   #6
joe r
Member#: 53412
2003 Outback
Black and Gold.
Thanks for all the info but please like legacy777 & I are asking there has to be somebody with the 6 pin harness premade or some one please if you have done it before help us.
joe r
Old 01-03-2005, 10:47 PM   #7
Legacy777
Member#: 4800
this thread may help
http://www.scoobymods.com/forums/showthread.php?t=2416
It may give me enough info to reverse engineer the pins and setup for mine. Looks like a good weekend project
Old 01-03-2005, 11:04 PM   #8
Legacy777
Member#: 4800
Old 01-03-2005, 11:06 PM   #9
Legacy777
Member#: 4800
I don't mind making the harness. I've actually got connectors for mine. I just need the correct pinouts.
I think with all the info I found in these threads, I'll probably be able to test the entire circuit this weekend and verify which pins do what, and create a diagram to make my harness.
Josh
Old 01-03-2005, 11:08 PM   #10
joe r
Member#: 53412
2003 Outback
Black and Gold.
Josh you friggin rock dude.I owe you a case of beer.
joe r
Old 01-04-2005, 09:50 AM   #11
Legacy777
Member#: 4800
I just re-read my post, and it might have been misleading. I don't mind fabbing up a harness for my lights. It'd be kind of hard to do one for yours because it's different, but I can try and help you get all the pins identified, so you can wire it yourself.
Old 01-04-2005, 12:30 PM   #12
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
Hi guys -- my familiarity is with the EDM 4-pin switch, which *should* incidentally, correspond to a 3-wire connection on the headlight. Here's my writeup on it in this thread:
my write-up on how I successfully wired up my orciari's and my take on how the EDM 4-pin switch/3-wire levelling system works:
http://forums.nasioc.com/forums/show...velling+switch
For the JDM 6-pin switch, there have been various write-ups in the past, and I think a board member (wagons ho, IIRC) even has a plug-and-play harness available using OEM connectors (to which he had to go to great pains to source I believe). For this information, check the following threads:
original hunt for levelling switch info:
wagons ho thread:
some JDM 6 pin pinout -- but not sure if it is confirmed?
http://forums.nasioc.com/forums/show...h&pagenumber=4
hope that helps!
-- Dendrobium
Dendrobium is offline   Reply With Quote
Old 01-04-2005, 12:36 PM   #13
Legacy777
Member#: 4800
Thanks!
I'll have to read over that info as well.
Josh
Old 01-07-2005, 03:42 PM   #14
AzN121184
Member#: 40943
2003 subaru wrx
aspen white
wagons ho thread:
hope that helps!
-- Dendrobium
so for jdm HID it uses a 6 pin?
AzN121184 is offline   Reply With Quote
Old 05-27-2005, 02:06 AM   #15
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
What type is the USDM STi leveller switch considered? JDM or EDM???
MK19_ is offline   Reply With Quote
Old 05-27-2005, 02:28 AM   #16
joe r
Member#: 53412
2003 Outback
Black and Gold.
Both.
It is the 6pin plug.
joe r
Old 05-29-2005, 11:29 PM   #17
MK19_
Member#: 49148
Dogs are forever in
OK, all done... 4 hours later. Took the time to remove the drivers side fender to route the harness I made for a cleaner install. I used the USDM 6 pin switch on my 6 pin STi EDM's and worked like a champ!!!!
vf34 low boost levels someoen please help sonicwrxpa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-10-2007 11:59 AM
Stock cd player questions? Please help. SanMateo Bay Area Impreza Club Forum -- BAIC 6 05-05-2004 11:18 PM
('93-'01) please help!! 98 GC8 bumper conversion question, please help!! nateconnella Impreza Forum 10 05-13-2003 05:50 PM
('93-'01) please help!! 98 GC8 bumper conversion question, please help!! nateconnella Impreza Forum 1 05-05-2003 10:11 PM
very easy question. Please help! vaporeso Car Audio, Video & Security 2 05-08-2001 08:40 AM
