Old 01-03-2005, 05:12 AM   #1
Umphreys448
Member#: 73519
2003 WRX
Default Voiding my Extended 4 Year / 40,000 Mile Warranty
I want to get an EcuTeK reflash, APS TBE, APS BOV, and possibly an UpPipe. Will this stuff void my warranty on the other parts in the car? Obviously it doesnt cover aftermarket, but I don't want an ecu reflash to void the warranty on my tranny, per say.
Umphreys448 is offline   Reply With Quote
Old 01-03-2005, 06:46 AM   #2
leecea
Member#: 37359
2003 WRX
Warranty issues are unpredictable, but IMHO anything that increases engine power would offer the dealer an opportunity to say it caused the tranny failure and hence no warranty.
leecea is offline   Reply With Quote
Old 01-04-2005, 04:15 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
leecea's right; I wouldn't plan on making any powertrain warranty claims with the reflash or uppipe, and probably with the TBE.
Old 01-04-2005, 05:00 PM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
the dealer would not know if you have an ecu flash... The other visual mods would be what you should be concerned about.
I would think that you should be fine with those mods, BUT I would leave off the BOV if I were you.. Best to keep things as stock-looking as possible under the hood. If they ever look under there, it will be the first thing they notice...
I wouldn't think you would be hassled about an exhaust...
Or for an Uppipe (Just get a JDM WRX one since it looks identical to the stocker, but without the cat).
jigga is offline   Reply With Quote
Old 01-04-2005, 07:23 PM   #5
Umphreys448
Member#: 73519
2003 WRX
Yeah but without the BOV wouldn't the increased PSI propose a bigger problem? I think the BOV would help me keep the warranty cause it would decrease the likelyhood of damage.
Old 01-04-2005, 07:27 PM   #6
Silverboost
Member#: 42387
2002 wrx
If you care about your warranty dont touch the car. If you are like me and some others and dont care then start modding the car. ecu reflash if you get that done you should be fine. but after that everything else like the uppipe, tbe, and etc they will void it. Unless you have a cool subaru dealer by you and they dont care what you do to the car and still will warranty it.
Silverboost is offline   Reply With Quote
Old 01-04-2005, 07:28 PM   #7
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
While that's true today, apparently Subaru is introducing some equipment that will allow some reflashes to be detected.
Most likely you won't be needing any warranty service anyway; however, if warranty coverage is important to you, research your mods carefully -- you may have to choose between modding and warranty.
Old 01-04-2005, 10:04 PM   #8
Killian Maynard
Member#: 73734
2005 WRX I caught
you a delicious bass
My advice would be to go with an Accessport so you can flash your ecu back to stock if you have to take it to the dealership. An up pipe and downpipe will be blamed for any problems in the drivetrain and engine. An upipe would be hard to hide since you usually remove an egt sensor with aftermarket units. This isnt the "right" thing to do but if you are somewhat handy with a wrench become familiar with removing and installing a downpipe if you want to be in the stage 2 range. Oh and have a nice supply of dp gaskets.
Killian Maynard is offline   Reply With Quote
Old 01-05-2005, 11:41 AM   #9
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
The stock BPV on the car is good for around 20PSI of boost.
If you want to run more boost, then look into eitther doing the CRUSH trick on the stock BPV, or look into picking up a JDM STi one, which will handle more boost.
I went back to mine on my car (I had an aftermarket one) , and no leakage occurs... And I am running a much bigger turbo than stock, fmic, etc, laying down over 300whp.
Armand1 - Yes, Subaru introduced some new technology with the newer ecu's to detect reflashes, but you have to look at things this way...
Before the dealer will think to check if you have a reflash, the other mods on the car will tip them off to deny warranty(ie: aftermarket turbo, FMIC, aftermarket injectors, aftermarket BOV, etc).
The stock computer will handle simple mods like the ones the original poster wantes to perform without resorting to a reflash. It is when heavy mods are performed that a reflash is really needed, and it is THOSE mods that will cause the dealer to raise the flag, before they would even think to go check the ecu to see if it was flashed in the first place....
I think the best thing to do is to go to a dealer, and have a talk with them about acceptable "accessories"
Old 01-05-2005, 11:43 AM   #10
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
If the stock up pipe is gutted, nobody looking at the car is any wiser
Old 01-06-2005, 05:24 PM   #11
SchnorrCS
Member#: 66383
Tom@ Kartboy is my
Daddy!
Also, if your really handy, you can always swap out the down pipe and cat back before you take it to the dealership. Obviously, the uppipe is harder. I weigh it as 3 hours compared to a voided warranty issue on a tranny. Worth it to me.
This goes for any aftermarket parts. All you need is tools. Kinda sh!**? way of doing business, but it will save you some loot, then you can get more parts....
SchnorrCS is offline   Reply With Quote
Old 01-08-2005, 11:52 AM   #12
t_wrexxx
Member#: 42790
2002 Bugeye
Be careful. I was denied warranty work with a boost controller, blow off valve, and catback exhaust.
t_wrexxx is offline   Reply With Quote
Old 01-08-2005, 05:59 PM   #13
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Originally Posted by t_wrexxx
... a boost controller, blow off valve, and catback exhaust.
I bet the boost controller was their major issue.
Old 01-08-2005, 06:03 PM   #14
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yes blow off valve causes tranny failures all the time according to subaru
but if you think about it, it does, statically because people who put one on are more likely to destroy their tranny
"flame suit on"
Old 01-09-2005, 12:16 PM   #15
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
"flame suit on"
statistically subaru trannys suck and must be babied. Subaru trannys come pre-assembled with a blow-up valve.
Chris N is offline   Reply With Quote
Old 01-10-2005, 03:37 AM   #16
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
not necessarily
my friends roommate is a HARDCORE gvr4 guy, and my friend is a hardcore subaru guy
both admit that any awd tranny isnt going to hold up to hardcore abuse
if you look at the GOOD drivers on this board, some have stock trannys running 350whp through them
theres some people like drac9 who has around that much on a stock rs tranny
youve just got to know what youre doing
Old 01-10-2005, 08:00 AM   #17
leecea
Member#: 37359
2003 WRX
"flame suit on"
This is exactly right. I have done no drivetrain mods, but a dealer will see my suspension mods and shift light and immediatly label me as a car abuser or performance oriented driver, depending on their mood. Either way, I am more likely to have done things that stress the tranny, wheel bearings, etc, etc and my warranty will be questioned. I don't like it, because I try to take good care of my car, but I think anyone who does any mods should face the fact that they may be paying the repair bills themselves.
Old 01-10-2005, 10:33 AM   #18
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yuppp
GM Adds 5-Year/100,000-Mile Powertrain Limited Warranty to GM Certified Used Vehicles NYCshopper Non-Subaru News & Rumors 3 02-02-2007 09:35 PM
Anyone elso think a 3 yr,/36,000 mile warranty these days sucks? dingo dave General Community 33 03-02-2003 04:04 AM
Should i get the 60,000 mile warranty? krillz Warranty Issues & SOA Problems 1 12-08-2002 01:20 PM
voiding my extended warranty wcfields Newbies & FAQs 15 10-14-2002 11:59 PM
40,000 miles on my WRX psoper Bay Area Impreza Club Forum -- BAIC 6 05-28-2002 06:30 PM
