Old 01-03-2005, 09:51 AM   #1
kevingroover
Member#: 46484
2002 WRX Wagon
Default IAC valve
Can someone please tell me what size the torx or torx plus screw that holds the IAC valve on a 2002 wrx is.
possibly unabomber?
kevingroover is offline   Reply With Quote
Old 01-03-2005, 12:17 PM   #2
kickin_81
Member#: 16679
2004 Forester XT
I used an impact wrench that you hit it on the top with a hammer to untorque the "+" screws. They're on pretty tight from the factory, and you can easily strip the screws if you're not careful. The other screws with a star end are tamper-resistant screws that are designed so you don't get into the mechanical parts of the IAC. This happened to me on my MY02 WRX motor.
kickin_81 is offline   Reply With Quote
Old 03-05-2005, 09:02 PM   #3
deadeye
Member#: 82459
2002 Impreza WRX
Rally Blue
To thoroghly clean the IAC do you have to remove these tamper resistant screws? I am trying to clean the IAC before I pay alot to replace it.
deadeye is offline   Reply With Quote
Old 03-05-2005, 11:19 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
those screws aren't torx (torx has 6 points) - they look like pentadrive.
Old 03-06-2005, 03:53 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
They look like Torx, but are not. I just found out a week or two ago they are tamper resistant. Apparently they are Torx in shape, but have a slight taper to them and require a special tool to properly remove. I guess it's a Torx with a rounded head similar to the ball hex. It may be pentadrive as mentioned above, but I am not familar with it. When I cleaned mine I remove the + screws and cleaned with Q-tips and alcohol. I did try a Torx of the proper size, but it didn't work.
Old 03-06-2005, 05:02 PM   #6
Vibeeleven
Member#: 77005
I have the same problem with my iac. I can hear/feel the motor trying to move the rod, but it stays in the same position wheather it's getting signal and when it's off, wich leads me to believe it's stuck. Is thier a way to unstick it? also what position should the rod be in when it's on and off? Thanks guys
Vibeeleven is offline   Reply With Quote
Old 06-01-2005, 10:26 AM   #7
LDragon
Member#: 3529
2003 FX45
Brownish
"Is thier a way to unstick it? also what position should the rod be in when it's on and off?"
does anyone have an answer for vibeleven above? this IAC valve is driving me crazy. i can;t drive my car with it idling at 2000 rpms.
LDragon is offline   Reply With Quote
IAC valve replacement? Pi7467mp Service & Maintenance 12 03-05-2005 08:53 PM
Need an IAC valve asap! Someone please send me one! Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-13-2004 02:09 PM
IAC valve subiekid Subaru Conversions 1 10-04-2003 08:00 PM
Looking for IAC valve for 2002 WRX pjcoregon North West Impreza Club Forum -- NWIC 0 05-20-2003 12:46 PM
2.2 ECU on 2.5 motor.. IAC valve problem Murray Engine Management & Tuning 6 12-30-2002 11:01 PM
