Old 01-03-2005, 01:07 PM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default short video of the broken Power steering pulley
http://www.vincentfurniture.com/phot...enpspump-1.wmv
And how it broke. Listen carefully during the second donut you hear a thumping whappping sound. Not good.
http://www.vincentfurniture.com/phot...gthepump-1.wmv
Old 01-03-2005, 05:35 PM   #2
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Oh No! So what are your plans now? Also, I never heard anything that sounded like it broke or was breaking. The car as a whole sounds awesome man. I love it.
Kevin Thomas is offline   Reply With Quote
Old 01-03-2005, 06:04 PM   #3
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
that car is tottally P I M P. hearing the sc spool up makes me really miss my car. - IC
IdenityCrisis is offline   Reply With Quote
Old 01-03-2005, 06:31 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
So that was the powersteering pump that I ripped the shaft right out. I was in a snow park up on MT Hood, had parked and videod a couple other wagons doing donuts. Then my turn. Got in the car, started it, got on boost and it broke instantly but I didnt know it until about 2 power slides 4 seconds later. On the video you hear the SC then a horrible banging flapping sound.
Never trust aluminium to hold a bolt. Especially small bolts. I should have backed up the bolts with nuts instead of just threads in the pulley.
The pulley came slightly loose from the core of the original powersteering pulley it was "bolted" to. With that slight play all hell broke loose. The shaft of the powersteering pulley then shattered the front of the powersteering pump and yanked the shaft clean out and shredded one belt pretty good.
And of course I didnt bring a spare belt to just drive the altenator. So I had to drive on just the battery down the mountain until the battery gave up the ghost. Luckily my brother was home so he drove out and saved me and we picked up a belt in Sandy and I was able to drive it back to the shop.
After I got back to the shop, I remounted the step pulley back onto the powersteering core AFTER I bent parts of it back into shape. It was pretty ugly looking. Then I had to return the pulley again. I am running out of metal to turn! I actually do need to turn another pulley now because of all these trial and ERRORS!
So 2 1/2 hours later, I was back on boost. But I was ragged and tired. oophhh.....
And.....I have a horrible knock/tapping sound now that won't go away. I have always had a tapping/knocking sound, even since I rebuilt the motor with new pistons and rings back in September, but it always went away after warming up. I don't know if it is the valve train (I hope) or rod knock. I am about 90% sure it is NOT because of the 10 psi of boost I was running since yesterday because the sound wasn't there this morning (or was it?) but rather since I strained the belt system so hard I destroyed the pump.
While fearful for the bottom end, I guess I will just have to give it some boost and see if it holds up. If it breaks, well, thats what the donor motor is for.
Why does power cost so much money and time?
Edit...Oh yeah, I put a spare powersteering pump in!
I am up and running again, but have another boost leak or slipping belt to deal with, as I am only getting 3-5psi again.
Old 01-03-2005, 06:49 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Hmmm... more noise + dropped boost? Got a compression tester?
I think I *might* have some phase 2 EJ22 pistons in my garage from a stock block, but I'm not sure. If you're in need, I can take a look.
Old 01-03-2005, 07:35 PM   #6
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
i'll have a rs 2.5 sb soon if you want that, #4 is toasted tho. - IC
Old 01-03-2005, 08:08 PM   #7
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I think it is belt slippage. As I have had to keep fixing the pulley, it keeps getting smaller, and smaller and smaller. Right now I can get 7 psi in high gears to start with but it tapers off as the rpms climb. And this was gained by just cranking the belt as tight as I could get it (which isnt good period to start with). This was happening the first time when I just had to tighten the belt enough for the 10 psi to show.
I think I am just going to bite the bullet and unhook the SC until I can find the time to turn another pulley. I will also make this pulley much larger, but keep the ratio the same for the 10 psi (maybe drop it to 8-9 psi just to be safe). This way my powersteering pump isnt being so overdriven.
Ah, if I had just known then what I know now.
Old 01-04-2005, 01:50 AM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Heh, why not just go with a toothed belt & pulley setup?
Went rotated? Tired of the stock power steering lines? SloRice Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 304 08-08-2016 12:49 PM
Short video of EJ22 powered Beetle camshaftprelube Subaru Conversions 19 10-28-2008 10:43 PM
Anyone know how to remove a broken power steering pulley off a chevy 350? BGPunk2001 Off-Topic 14 05-17-2008 06:59 PM
A Short Video of the "Pre-Christmas Cruise 2007" jal723 Vancouver Impreza Club Forum -- VIC 26 11-14-2007 07:30 PM
Short video of the outback seeing snow for the first time. remarcable Legacy Forum 0 01-03-2002 09:26 PM
