Old 01-03-2005, 06:03 PM   #1
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Question What 3 gauges needed?
I’m looking into monitoring for my WRX drivetrain (swap) and am considering installing 3 sweeper gauges in an available DIN slot. But which three would be most beneficial? Obviously boost is the most important as I presently have no means of monitoring, but what about the other two?
1. Boost
2. Air/Fuel Ratio, Fuel Pressure, Intake Temp.
3. Oil Pressure, Oil Temperature, Pyrometer (EGT).
Obviously fuel level and water temp can be monitored from the stock cluster.
All comments appreciated…
xcntrk75 is offline   Reply With Quote
Old 01-03-2005, 06:11 PM   #2
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
I like oil pressure alot because it gives you an early warning of possible engine problems.
wrx05 is offline   Reply With Quote
Old 01-03-2005, 06:27 PM   #3
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
Boost, Wideband 02, and then its up to you. Oil temp is easy to put in and cheep, but oil pressure and fuel pressure are good ones to have. EGT is good but now that wideband 02 kits (A/F) have gone down in price that would be better to get.
http://store.yahoo.com/fastwrx/plxmwio2seki.html
Tur1smoWRX is offline   Reply With Quote
Old 01-03-2005, 06:31 PM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Wideband O2
Good tip… I would like to air/fuel mixture but your standard sweeper (1volt) simply won’t cut it and is more of an average if anything. A 5volt system like the Wideband would be sweet… Anybody make one in a 2 1/6 (52mm) round gauge housing?
Old 01-03-2005, 09:27 PM   #5
AngryBlueRS
Member#: 51678
05 STI
87 Rocco dirt beast
Boost, wide-band O2 and oil temp. The oil temp is a good choice if you do a lot of hard driving as the engine and oil temp can vary drastically. Also a good monitor to have if you do not have a turbo timer to regulate the temp before shutdown.
HTH,
Chris
AngryBlueRS is offline   Reply With Quote
Old 01-03-2005, 09:40 PM   #6
damn_4eat
Member#: 57964
2003 Impreza
Pollen infused
boost, oil pressure, egt
damn_4eat is offline   Reply With Quote
Old 01-03-2005, 10:33 PM   #7
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
The wideband 02 kit that Mach V sells has a add on bit that will let you hook up a 52mm gauge such as AutoMeter gauges. Or if your question was just about gauge housing then there are many solutions for that. I.E. : clock spot, A piller, gauge cluster, or steering column.
Need help on what is exactly need for BIG 3 04ImprezaWRX Car Audio, Video & Security 7 06-09-2008 01:44 AM
What color gauges? Need Opinions! 4thgenx42 Interior & Exterior Modification 10 11-12-2007 09:03 PM
What 3 gauges would you get?? offset STi Forum Archive 7 07-14-2003 03:31 PM
What 3 gauges do i need? wReXeRw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 07-11-2002 11:05 PM
What 3 gauges woud you get? gpxl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-06-2001 01:52 AM
