Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 01-03-2005, 07:41 PM   #1
sunbum
Member#: 45106
2004 WRX PSM Wagon
'68 IH Scout
Default 02/03 springs/struts on an '04
I've managed to come up with a set of 02/03 struts with Prodrive springs completely assembled as they had been on Dunk's car (thanks again Dunk!). I'd heard someone else mention that I'll need to get the 02/03 top hats for them to work on my 04 wagon, but I'd think that since the entire spring and strut is already together, I could just swap the units in place of my current struts and springs and be done with it. What am I missing?
thanks,
Myron
sunbum is offline   Reply With Quote
Old 01-03-2005, 07:51 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the rear strut tops are different.
the 04's are more rectangular while
the 02-03 are round. so I would double
check the clearance you have for the reat strut tops.
other that that if there is enough room why not.
Old 01-03-2005, 08:06 PM   #3
TopKatz
Member#: 36793
04 WRX
I had 02/03 prodrive springs on a 04 sadan. I used the 02/03 top-hats, with the stock struts.
I was not happy with the end result. I thought the front end was to low, and I was always hitting the bump stops. The car was under dampened, and I it just felt wrong.
I took those out and replaced them with a set of STI v8 take offs.
I'm not sure if my car behaved like an 02/03 with the prodrives would have. I just know that I did not like the results.
Katz
TopKatz is offline   Reply With Quote
Old 01-04-2005, 12:43 AM   #4
Mark Avery
Member#: 10313
2002 WRX wagon
If the springs/struts/strut tops are all one assembly, it will bolt into your car no questions asked.
The question you should be asking though, is: "Why would I want to put old used 02 struts in my car when I have better, newer 04 struts?"
Mark Avery is offline   Reply With Quote
Old 01-04-2005, 05:52 AM   #5
sunbum
Member#: 45106
2004 WRX PSM Wagon
'68 IH Scout
My reasoning is that the install would be loads easier to undo if I didn't like the end result of the swap. It'll be a few weekends before I have enough free time to put them in, so I'l cogitate on it a bit more.
05 STI Springs/Struts on an 03 WRX Sedan gramadin Brakes, Steering & Suspension 2 02-11-2009 08:47 PM
02-03 downpipe + midpipe fitting an '04 rich22 Factory 2.0L Turbo Powertrain 2 04-08-2008 11:37 AM
02-03 springs/struts/tophats(NEW) blkandbluwrx Suspension/Brakes/Handling 9 10-30-2007 10:45 AM
FS: 02-03 WRX Struts on Prodrive Springs HS WRB-rex Suspension/Brakes/Handling 5 10-11-2006 01:01 AM
Will 02/03 WRX struts fit an 04/05 WRX? GADGTGUY Brakes, Steering & Suspension 2 05-06-2005 10:30 AM
