Old 01-04-2005, 01:39 AM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Default wierd utec logs plus maxing out injectors on stage 1 base map
i dunno why but my modified maf voltage looks wierd for example in the very last line in the following log my real maf is 3.9 and i add 2.4% fuel and my modified maf is still 3.9. does anythone know what can be going on.
plus im maxing out my injectors on the txs base map i have been taking out fule in some areas but it still maxes them out.
PHP Code:
 6447
+11.5 4.1 103  60    00   rich +27.2   97.2 +25.0  -1.3 380.00 4.1
 6397
+11.3 4.1 103  60    00   rich +27.2  ---.- +25.0  -1.3 380.00 4.1
 6472
+10.6 4.2 103  60    00   rich +27.7   97.7 +25.0  -1.4 380.00 4.1
 6385
+11.0 4.1  45  60    00   rich +31.4   34.2 +25.0  -1.1 300.00 2.2
 6172
+6.6 2.0   0  00    00   rich +10.7   11.7 ECU.   +0.5 ECU.   2.1
 5858
+0.8 2.2   0  00    00   rich +11.5   13.5 ECU.   +0.2 ECU.   2.4
 6071
-3.0 3.5  73  10    00   rich +22.7   68.4 +25.0  -1.6 380.00 3.7
 6361
+13.1 4.1 103  70    00   rich +27.5   95.8 +25.0  -1.6 380.00 4.1
 6435
+12.5 4.1 103  70    00   rich +27.9   94.8 +25.0  -1.6 380.00 4.0
 6435
+12.7 4.2 103  70    00   rich +28.0  ---.- +25.0  -1.7 380.00 4.1
 6510
+12.5 4.2 103  70    00   rich +28.5   96.4 +25.0  -1.8 380.00 4.1
 6574
+12.7 4.1 103  70    00   rich +28.5   96.5 +25.0  -1.8 380.00 4.1
 6385
+10.6 2.4   0  00    00   rich +11.0   12.4 ECU.   +0.4 ECU.   2.2
 6172
+4.9 2.1   0  00    00   rich +10.7   12.9 ECU.   +0.5 ECU.   2.2
 6510
+0.4 3.5  51  10    00   rich +41.1   67.5 +25.0  -1.5 ECU.   3.7
 6093
-1.8 4.1 103  10    00   rich +25.7   90.5 +24.0  -1.8 380.00 4.1
 4938
+1.1 4.2 104  50    00   rich +16.7   98.9 +21.6  +0.5 380.00 4.1
 4768
+7.2 4.0 103  80    00   rich +15.1   88.8 +20.4  +1.4 380.00 4.0
 4844
+11.5 4.0 103  70    00   rich +15.2   84.0 +21.0  +0.9 380.00 4.0
 4967
+14.1 3.9 103  70    00   rich +18.4   81.3 +21.6  +0.9 380.00 4.0
6207
+11.9 4.1 102  60    00   rich +20.2   99.3 +24.3  -1.0 380.00 4.1
 6184
+11.5 4.1 103  60    00   rich +20.4   99.2 +24.8  -1.0 380.00 4.1
 6325
+11.3 4.1 103  60    00   rich +23.8   99.8 +25.0  -1.5 380.00 4.1
 6289
+11.7 4.1 104  60    00   rich +23.9   99.9 +25.0  -1.1 380.00 4.1
 6349
+11.9 4.1 104  70    00   rich +24.0   96.8 +25.0  -1.5 380.00 4.1
 6373
+12.1 4.1 103  70    00   rich +23.9  ---.- +25.0  -1.6 380.00 4.1
 6485
+12.1 4.1 104  70    00   rich +24.1   98.1 +25.0  -1.6 380.00 4.1
 6485
+12.7 4.1  93  70    00   rich +24.6  ---.- +25.0  -1.7 380.00 4.0
 6410
+9.4 2.1   0  00    00   rich +10.7   12.4 ECU.   +0.4 ECU.   2.0
 6006
+3.5 2.2   0  00    00   rich +11.2   13.0 ECU.   +0.5 ECU.   2.1
 5688
-2.4 2.2   0  00    00   rich +10.8   13.7 ECU.   +0.1 ECU.   2.4
 5777
-7.1 3.4  46  10    00   rich +22.8   56.8 +23.0  -1.8 380.00 3.6
 5367
-6.1 4.0  99  10    00   rich +19.6   88.9 +23.0  -1.7 380.00 4.0
 5282
+0.6 4.2 103  60    00   rich +15.6  ---.- +23.0  -0.4 380.00 4.1
 4610
+8.2 4.1 103  90    00   rich  +9.6   86.6 +19.8  +2.6 380.00 4.0
 4734
+13.5 3.8 103  90    00   rich +10.4   78.2 +20.4  -0.1 380.00 3.9
 4748
+15.5 3.9 104  80    00   rich +11.0   86.9 +19.9  +2.4 380.00 3.9
NITROS is offline   Reply With Quote
Old 01-04-2005, 03:00 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
3.85 (which would round to 3.9) multiplied by 1.024 (adding 2.4%) == 3.942... so even before and after correction, you would read 3.9. *shrug* Just some quick math.
Old 01-04-2005, 10:16 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
do you have injector scaling turned on?
Old 01-04-2005, 11:56 AM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Lots of people have reported maxing out the injectors on the base maps. TXS has very rich base maps and maxing them out isn't abnormal.
cdvma is offline   Reply With Quote
Old 01-04-2005, 09:04 PM   #5
jefersun
Member#: 37716
2002 ej257 Black WRX
I second that... a friend of mine has a STi w/ utec and txs base map and he gets close to maxing out his 565s out when it gets cold (i.e. more boost = more fuel)
jefersun is offline   Reply With Quote
Help with Stage 1 base map WhiteReX Open Source Reflashes 1 04-19-2010 11:33 AM
Stage 1 Base MAP ON TOP of Real TIme MAP? jeraljay AccessPort 3 08-20-2007 09:27 PM
UTEC Logs, Stage 2 Maxing Out Injectors lancelucas UTEC 12 11-13-2006 03:20 AM
UTEC Newbie - STi Stage 2 Base Map Log MattSTi Engine Management & Tuning 4 12-14-2004 07:45 AM
maxing out injectors on turbo xs stage 2? ilivas Engine Management & Tuning 6 03-19-2004 02:23 PM
