Old 01-04-2005, 02:00 PM   #1
bryan carbon
Member#: 34060
Default cm2 converted to A/R.
6 cm2 = 0.41 A/R
7 cm2 = 0.49 A/R
8 cm2 = 0.57 A/R
9 cm2 = 0.65 A/R
10 cm2 = 0.73 A/R
11 cm2 = 0.81 A/R
12 cm2 = 0.89 A/R
Found that on stealth316's website.
bryan carbon is offline   Reply With Quote
Old 01-05-2005, 12:26 AM   #2
JalopySiR
Member#: 39378
2004 Carless
98' VFR800Fi/02' RC-51
T25 or T3 turbine housing?
JalopySiR is offline   Reply With Quote
Old 01-05-2005, 04:33 AM   #3
0db
Member#: 33879
2003 WRX Sporkwagon
I'm pretty sure those two numbers are referring to two very distinct and separate aspects of turbine geometry. That correlation may hold true for one particular turbine casting but that's it.
0db is offline   Reply With Quote
Old 01-05-2005, 10:24 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes. we have the "As" given, but we do not know the "Rs" to give us the proper ratio.
Old 01-05-2005, 11:51 AM   #5
ataac_flat04
Member#: 19050
2005 Black STi
Happily rowing 6 gears
For that chart to be useful, we would need to know which Garrett housings it is converting to. T25, T3, T4, etc. To compare nozzle/inlet area (which is the 6cm^2 designation) to A/R we need to know which housings you mean. It's entirely possible to have a T3 and a T4 housing with the same 0.63 A/R, but the T4 housing nozzle area will be larger than the T3's. So for example, the T3 0.63 A/R could be close to a 7cm^2 housing, whereas the T4 0.63 A/R could be closer to 10cm^2 (due to a bigger inlet). <--- prolly not exact conversions, shown for illustration puropses only, I performed no math to get these numbers, just estimations. HTH's -Chuck
ataac_flat04 is offline   Reply With Quote
Help - anyone know of a free converter to convert .rm files to .avi? GodWhomIsMike Off-Topic 1 10-11-2007 02:51 PM
How to convert to FWD? djerickd Transmission (AT/MT) & Driveline 16 10-04-2002 06:49 PM
How much to convert to WRX look? Dai Vancouver Impreza Club Forum -- VIC 2 07-26-2002 11:33 PM
How to convert to AWD?? PURE EPI Mid Atlantic Impreza Club -- MAIC 1 11-22-2001 12:28 PM
MY99 How Hard to convert to rear wheel drive???? Xscreamer Normally Aspirated Powertrain 12 05-24-2001 05:28 AM
