Old 01-04-2005, 03:54 PM   #1
dingo dave
Member#: 33177
2000 Impreza RS coup
white
Default Would grounding mod cease static in AM reception?
It's wierd, sometimes my AM reception is filled with static, sometimes it's fine. Also, the higher i turn the AC on the worse the static gets. Would a grounding kit solve this issue?
dingo dave is offline   Reply With Quote
Old 01-04-2005, 06:35 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
It might improve things, but it's hard to say for sure.
Does it do it on all AM stations or only certain stations? Maybe the one you listen to most has signal issues. Next time it does it, take note of the weather.
Legacy777 is offline   Reply With Quote
Old 01-04-2005, 07:28 PM   #3
Caliber
Member#: 40199
2003 WRX
Platinum
Well with the a/c switch your changing (reduce) the resistence to ground, to increase the blower speed.
A grounding mod might help a little, but only trying it will give you the anwser.
Caliber is offline   Reply With Quote
Old 01-05-2005, 09:35 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
an inductive/capacitve noise filter in the power lead to the radio would probably be much more efficient at keeping hash from the radio power supply (and ultimately the speakers). you can get 'em at radioshack, etc.
jm2c
ken
Old 01-05-2005, 10:02 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Noise pickup on AM is usually radiated RF pickup through the antenna rather than from the power, if it's power you'll get it through the HU in all modes (AM, FM, CD).
If the noise is changing with the blower speed (does it go away with the blower off?) the source is the blower motor itself, in this case a bypass capacitor across the motor leads might help.
Old 01-05-2005, 03:57 PM   #6
dingo dave
Member#: 33177
white
It goes away if the AC is turned off. Gets worse as the blower is turned up.
It does it on all AM stations.
Old 01-05-2005, 04:17 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
So the blower motor is definitely the source. A small capacitor (value .1uF or so) connected across the wires that go to the blower motor should reduce or eliminate it. The cap should be as close to the blower as possible.
Old 01-23-2011, 08:40 PM   #8
jdefils
Member#: 271394
2002 Impreza WRX
I had a similar problem with my WRX. What I found was that the antenna connection for the radio wasn't made up well.....I unplugged it/plugged it back in a number of times, and since then, no static.
jdefils is offline   Reply With Quote
Old 01-23-2011, 09:25 PM   #9
DeathSStar
Member#: 202982
If the blower motor is failing (brushes wearing out, etc) it can cause the RFI you describe, otherwise it can be a faulty connection at the blower motor wire harness or blower motor resistor pack. Check the wiring harnesses for corroded terminals, etc.
Does your blower sound noisier than normal, or make weird noises when running?
DeathSStar is offline   Reply With Quote
Old 01-23-2011, 10:15 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i had the same thing......
Old 01-24-2011, 07:45 PM   #11
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
AM static problems were fixed in the 1970's... its called FM. Then they fixed it yet again a few years ago... its called CD/Sat radio/ipod etc.
yamarocket630 is offline   Reply With Quote
Old 01-25-2011, 06:28 PM   #12
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
check radio antenna conection & also check that the radio to chassis ground wire is clean & solid.
a/c issue is unrelated... but as mentioned if the motor is failing it will emit RF static.
Rob
TXwrxWagon is offline   Reply With Quote
How would YOU mod it?? WrXLoLiS Newbies & FAQs 28 06-03-2010 08:18 AM
would ground mod cause p0420 cel? newbiescooby2.5rs Normally Aspirated Powertrain 0 02-12-2006 03:17 AM
Attn Hollywood: You've beaten this cliche into the ground. Please cease and desist. Asinine Off-Topic 80 02-10-2006 11:29 PM
Single-point ground mod vs. Multi-point ground mods DrBoy01 Normally Aspirated Powertrain 5 12-05-2003 04:21 PM
Ground mod creates static? M3sum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-03-2002 09:12 AM
