Old 01-04-2005, 04:29 PM   #1
kinger
Member#: 49328
2004 WRB/Gold STI
Default STI hitch wiring
Anyone know if this is all I need to splice into the wiring:
http://www.etrailer.com/Merchant2/me...egory_Code=VWH
Also where do I splice into for each of these sources? do I just take panels off and get at the tailights, brake, and turn signals?
Thanks!
kinger is offline   Reply With Quote
Old 01-05-2005, 12:07 AM   #2
XtremSTI
Member#: 77698
2004 Subaru STI
Black/Silver
what in the hell are you possible towing with an STI? Just curious
XtremSTI is offline   Reply With Quote
Old 01-05-2005, 02:25 AM   #3
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
track tires and a floor jack. Canopy, cooler and jack stands. lawn chair.
sounds like an Auto-X day to me
Rapid_Roo is offline   Reply With Quote
Old 01-05-2005, 09:04 AM   #4
kinger
Member#: 49328
2004 WRB/Gold STI
Auto X in summer and Snowmobile in the winter! This is the Ultimate sports car!
Old 01-05-2005, 09:49 AM   #5
XtremSTI
Member#: 77698
2004 Subaru STI
Black/Silver
I can understand the small tire trailer but a snowmobile? Thats kinda big
Old 01-05-2005, 11:09 AM   #6
kinger
Member#: 49328
2004 WRB/Gold STI
Can any one help me with the wiring? Mainly wondering if I need a module or if I can tap directly into the stock wires for each lamp? Thanks
Old 01-05-2005, 11:21 AM   #7
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
I believe you should be able to tap into the stock wiring.
A module is only needed if you have something like braking asistance.
...This thread reminds me of the Hemi commercial.
"that thing got a turbo?"
"Yeah"
"cool"
Sti beats them to the next stoplight while towing a snowmobile
tooocool49723 is offline   Reply With Quote
Old 01-05-2005, 12:08 PM   #8
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
You should be able to tap into the lights, just use another set of relay to power the lights, and only use the taps as triggers for the relays.
I've never done a trailer hitch before, but I assume this method should work as I have done it this way for other things.
RR
Old 01-06-2005, 09:25 AM   #9
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
Get the harness from E-trailer--it is plug/play w/ the connecter inside the passenger-side tail light compartment.
Subahaulic is offline   Reply With Quote
Old 01-06-2005, 09:27 AM   #10
Subahaulic
Member#: 51163
Get the harness from E-trailer--it is plug/play w/ the connecter inside the passenger-side tail light compartment. There's a grommeted hole to run the harness cleanly to the hitch there as well.
Old 01-06-2005, 12:16 PM   #11
kinger
Member#: 49328
2004 WRB/Gold STI
Plug and play? Mmm I know your wagon had a OEM part that was plug and play but from my understanding there is no part on the STI, guess they don't think 300/300 hp/tq can tow
Old 01-06-2005, 12:39 PM   #12
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
really interesting...
does that harness have an out put for the reverse and signal lights as well?
got a link to that. I didn't see anything like it on their site.
Old 01-06-2005, 12:59 PM   #13
kinger
Member#: 49328
2004 WRB/Gold STI
If you go to thier site and look at the PnP "T" connector you input your model and it gives you the PnP harness. It lists one for the FXT but not the impreza and it reccomends a hardwired modulite module that you hook a 12V+ to so that your turn signals will act as a signal to a relay and then the trailer lights draw from the 12V source. Looks like you tap the different signals to the "IN" of the module and the "OUT" is the 4 plug connector you run out to the trailer.
Old 01-06-2005, 02:19 PM   #14
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
cool thanks
WRX Trailer Hitch Wiring cheat sheet ANZAC_1915 Service & Maintenance 5 07-09-2015 11:37 AM
05 STI Trailer hitch wiring ??? Dwagner1006 Electrical & Lighting 4 12-15-2009 02:47 PM
04 STi Hitch Wiring - Power BritSti Electrical & Lighting 5 04-22-2005 05:14 AM
Hitch Wiring on 04 Sti, is it there? BritSti STi Forum Archive 0 09-02-2003 01:31 AM
