Old 01-05-2005, 12:08 AM   #1
jakepepe
Member#: 49779
Default ??'s on a temporary 2.5L swap to a 2.2L
I swapped my 2001 2.5L sohc that has 2.2L heads to a 2.2L 95 impreza motor due to a spun timing pulley. Its onl temp while i build up the 2.5L. I have a few questions though.... i bought the car with the 2.5
l with 2.2L heads what is the advantage of this? Wouldn't it seriously lower the flow rate? It must have some point because i have read about a few poeple doing it with built motors on this site. Anyway, i have pulled this 2.2 out twic now with no luck the throwout bering keeps comming off, at first i thought it was a bad throwout being so i pulled the motor and replaced it, i put the clips on correctly and when i was all said and done the motor still made the noise. I pulled the motor agian only to find the clips off! I reclipped it and put the motr back in and agian same thing? Is there a trick to keeping the clips on? Also i keep getting a stuttering and check engine light that reads a misfire in cyl 3. Sometimes it goes away but always comes back. There's also heavy amounts of black fluid shooting out my exhaust. Any sugesstions or helpful tips?
Next, I compression tested the 2.5L motr and found a 30% loss in the heas so i will be replacing them. I want to increase the power a little while i'm at it. I have a good set of stock 2.2l heads at the house that were just cleaned and tested witn no leaks. Can i put 2.5L agressive street cams from cobb in there or should i just spend the money and get the $2000 stage I 2.5L heads. I realy don't want to spend taht much money as it is.
P.s.--- The car is running off a 1.8L ecu. (possible problems there?) This car is a real hybrid!!
jakepepe is offline   Reply With Quote
Old 01-05-2005, 03:15 PM   #2
jakepepe
Member#: 49779
doesn't anyone have any insight on these things?
Old 01-05-2005, 03:27 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
why would you waste your $$ building up a 2.5
don't do it
your runing stupid rich ...
thus the black gook and misfires
Old 01-05-2005, 03:41 PM   #4
jakepepe
Member#: 49779
how can i correct that? Why is it reading as only cyl 3 misfire?
Old 01-06-2005, 07:02 PM   #5
jakepepe
Member#: 49779
cause i don't have the $$$ or the exp with wiring to do a wrx swap!!!
Old 01-11-2005, 12:07 PM   #6
jakepepe
Member#: 49779
does anyone know how to correct it from running so rich?
Old 01-11-2005, 12:45 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
2.5s on 1.8 ECUs always (or almost always) run rich.
I believe the fix is spreading out the timing map.
jamesfacts is offline   Reply With Quote
Old 01-12-2005, 03:24 PM   #8
jakepepe
Member#: 49779
how do i do that? external fuel management like apexi?
1998 2.5 swap to 1996 2.2 auto to 5spd gazdie Subaru Conversions 0 07-01-2008 11:53 PM
Just finshed a 2.2L to 2.5L SWAP..HAVING ROUGH IDOL PLEASE HELP gazdie Subaru Conversions 1 03-17-2008 10:21 PM
2.2L to 2.5L swap? PyronAbyss Subaru Conversions 11 03-14-2006 04:12 PM
2.2l 2.5l swap Shockey Normally Aspirated Powertrain 1 04-10-2005 01:21 PM
?'s about best 2.0 swap to 2.5 slida Subaru Conversions 4 01-12-2005 04:01 AM
