Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-05-2005, 01:35 AM   #1
phunk
Member#: 68227
Default EJ22 Turbo in a '90 Auto Wagon?
I am not sure if anyone can help me here or not...
I own a shop, and I DO NOT work on Subarus... i know little to nothing about them. At any rate, this car somehow ended up here.
I got a 1990 Wagon here, its and auto and originally a NA. The owner put in a turbo EJ22 engine, which he tells me is a USDM motor that was available in this car. I know nothing of Subaru trivia, so I am not sure how much is fact.
THe owner tells me he had a whole clip, and swapped the engine and absolutely everything else such as MAF sensor, etc. He says he swapped the wiring harness, and put in the turbo ECU. The original Auto trans remains.
So here is how it came to me... it doesnt start... just cranks and cranks. Its got fuel and spark. If we put back in what he says is the stock NA ECU it runs, but just barely and dies suddenly. On what is supposedly the turbo ECU, it appears to be flooding. Anyone know how I can tell the ECUs apart?
So at any rate, I just wanted to see if there is anything I should know about this before I start screwing around with it. I wonder if he got the ECUs mixed up and its actually the Turbo one that it barely runs on and possibly has some other stuff hooked up wrong... I have no idea what is different between the engines... Ignitor? Fuel Injectors? MAF? What is different between the two, and is this swap something that is commonly done?
I am not sure I even want to screw with this thing... but if any of you have some helpful suggestions so I can give this fellow back a car that runs without a $2000 bill for wiring and diagnostics... that would be nice.
Or, if any of you are in the Chicago area and feel up to the task, feel free to take this thing off my hands and make yourself some cash... I honestly have little to no desire to learn my way around this car or Subarus. No offense, I love the 2.5RS and later gens.... but I have my own niche that I work in.
Thanks,
Charles
phunk is offline   Reply With Quote
Old 01-05-2005, 02:09 AM   #2
happyparrot
Member#: 61896
1998 2.5rs S/C
RBP
Seems to me like he messed up the wiring for the CPS. (crank position sensor)... Atleast thats where I would start to look for the problem after I checked the spark timing, and fuel pressure. Check the injectors for pulse width, if you don't have any then you can assume its the CPS, if that checks out and you still have no pulse width, then just send him to a different shop.
happyparrot is offline   Reply With Quote
Old 01-05-2005, 02:12 AM   #3
phunk
Member#: 68227
thanks for your time.
I dont beleive that he wired anything... he said it all plugged in. I havent gone over any of the wiring yet.
Old 01-05-2005, 10:42 AM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I'd suggest going over to www.bbs.legacycentral.org
You're going to have better luck since it's devoted solely to the first gen legacies.
Do you have part #'s off the ECU's? If so, I can tell you which is which. Also, I'd suggest pulling the codes from the ECU. See if there is a sensor that is possibly causing this, or if it's more of a mechanical problem. Instructions and info is on my site www.surrealmirage.com/subaru
Josh
Legacy777 is offline   Reply With Quote
Turbo in an 01 LGT wagon. beastman487 Normally Aspirated with bolt-on Forced Induction Powertrain 6 03-22-2010 02:52 PM
part out - '90 legacy wagon brian123 Engine/Power/Exhaust 1 04-18-2007 03:12 AM
WTB Mid '90 Legacy Wagon Bakergtt NWIC Private Classifieds 2 01-27-2006 10:00 PM
A request for anyone with an EJ22 turbo or EJ18 NA motor in pieces (hey Fitz/Darshu!) North Ursalia New England Impreza Club Forum -- NESIC 10 02-14-2004 03:30 AM
FS in NY: '90 Talon TSi AWD 5-speed, needs to go ASAP fellfrosch7 Private Vehicle 'For Sale' Classifieds 1 10-14-2003 12:05 PM
