Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 01-05-2005, 01:15 PM   #1
sticky tires
Member#: 53985
Default Question about Cobb AP Stage 2.
Is it possible to have Cobb AP stage 2 w/ stock exhaust? From what I've searched, they say it's not possible.
Someone is claiming to have Cobb AP Stage 2 w/ stock exhaust. I need some confirmation. TIA.
sticky tires is offline   Reply With Quote
Old 01-05-2005, 01:17 PM   #2
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
I would not recommend using the Stage 2 map with stock exhaust. They tuned it that way for a reason. At the very least, you need a downpipe.
gjhsu is offline   Reply With Quote
Old 01-05-2005, 01:34 PM   #3
sticky tires
Member#: 53985
Will the Cobb AP Stage 2 do anything for a stock STi? From stock, I mean stock, exhaust, UP/DP.
Old 01-05-2005, 01:54 PM   #4
pezman04wrx
Member#: 66558
^^^ Ditto ... At a minimum you have to have the down pipe (or a downpipe in general, it doesn't need to be Cobb's) Otherwise you are simply Stage 1 using just the AP ... Your stock UP will be fine even when you do upgrade to Stage 2, but the DP is needed for Stage 2 and the TBE is highly recommended ...
pezman04wrx is offline   Reply With Quote
Old 01-05-2005, 02:03 PM   #5
sticky tires
Member#: 53985
Thanks.
Old 01-05-2005, 02:17 PM   #6
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
Stage 2 = more boost
More boost = more heat
Free flowing exhaust lets the heat escape better.
There is more to it than this, but just wanted to make this simple point.
Mattr762 is offline   Reply With Quote
Old 01-05-2005, 03:09 PM   #7
EnforcerPSU
Member#: 76849
2011 WRX
Rally Blue
If you install stage 2 without an aftermarket downpipe or new exhaust, how much HP do you think is lost?
EnforcerPSU is offline   Reply With Quote
Old 01-05-2005, 03:14 PM   #8
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
I have a e-mail from trey. Here it is:
Peter,
You can run the Stage2 mapping with that configuration. You may see
slightly less than the target boost due to the lack of a true turboback
but the end results should still be nice. Most importantly, it'll be safe.
Thanks,
Trey Cobb.
Now the question to Trey was if I could run stage 2 with a stock STI catback on a WRX with a Helix Catted DP.
Hope this helps.
darksands is offline   Reply With Quote
Old 01-06-2005, 04:35 PM   #9
hondaeater69
Member#: 60324
It's not a matter of losing HP, it's a matter of running an improper map for your setup. I would imagine you could run dangerously high EGT's raising the boost that much and keeping eveything stock, but if you like to play with fire be our guest. If you have a way to monitor EGT, Boost, AFR, and knock, then I would give it try, otherwise a DP is cheaper than a new short block
Question for those using the COBB AP Stage 2 The Reaper 975 AccessPort 16 02-21-2006 10:16 AM
COBB AP Stage 2 Boost + other questions kyoung05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-10-2006 04:35 PM
Cobb AP Stage 2 question MBasile Engine Management & Tuning 8 11-10-2005 06:35 PM
Cobb ap stage 2 question.... DeKaP Newbies & FAQs 9 09-15-2005 06:30 PM
Cobb AP Stage 2 on 2005 STi questions. twotacosfor99cents Engine Management & Tuning 9 01-06-2005 11:00 AM
