Old 01-05-2005, 02:31 PM   #1
kool168
Member#: 61006
Default UTEC tunning tips needed
utec tunning tips needed, how to tune the "chokes" on the ECU and UTEC cross over point during low load area.
thanks
kool168 is offline   Reply With Quote
Old 01-05-2005, 03:26 PM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
smooth the transitions. take lots of logs of the crossover. make changes to the low load areas of your maps so that your timing does not jump much when the utec takes control.
with the sti utec and no w/b you cannot look at afrs unfortunately, so only half the story. but a start nonetheless.
ken
Old 01-06-2005, 12:39 AM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Log the timing transitions and look at the injector duty cycle at the same time. Match them and the transition will be invisable. If you are running a stock intake then use ECU timing below 40% load column. The timing transition from 40% to 50% will be more consitant than from 0% to 10%. Then you just have to monitor what the fueling is doing. Monitor it going in and out of UTEC control. Once the UTEC is in control you can do whatever you like.
mick_the_ginge is offline   Reply With Quote
Old 01-06-2005, 01:40 PM   #4
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
fueling for me made the biggest changes in the hesitation.. I would start my car at 1.5K in 5th and do a pull to about 40% load then start at 2K and on up to starting about 3.5K... after each pull I'd adjust fueling to try to keep the AFR transition smooth.. this got rid of about 95% of the crossover issues.
MustGoFast is offline   Reply With Quote
Logging and Tunning Tip-in Enrichment Bizko1288 Open Source Reflashes 3 01-17-2010 06:15 PM
Need Utec tunned (Buffalo Grove) 4pOwnag3 Mid West Subaru Owners Club Forum -- MWSOC 6 05-14-2005 08:55 PM
ohh jebus need local utec tunning help? drifterx North West Impreza Club Forum -- NWIC 20 11-06-2003 11:31 PM
Utec tunning!! I need Help! mixup52 Engine Management & Tuning 6 08-07-2003 05:44 PM
Utec tunning RTP SPeeDSiN South East Region Forum 1 02-25-2003 01:19 PM
