Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 01-05-2005, 06:17 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Gruppe-S V2 Headers & Helix Components back in stock!
Gruppe-S V2 Manifold - 02+ WRX / 04+ STI $399 shipped !
The Gruppe-S manifold is a 4 to 1 manifold designed to provide extensive midrange and top-end power gains. Our manifold features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. Strong gains in both HP and torque can be expected with the addition of the manifold, especially with high horsepower applications. Includes all necessary gaskets.
Helix Flex Uppipe - 02+ WRX $199 shipped !
-High quality double layered flex section - Reduces torsional vibration on vital exhaust components and turbo, also ensures perfect seal (even with aftermarket headers, downpipes, etc.)
-Thick 1/2" 304 Stainless Steel Flanges - to prevent warping and reduce heat expansion
-304 Stainless Steel Mandrel Bent Piping - Ensures proper flow and durability
-CNC Machined EGT bung - seats EGT properly unlike competitors which will eventually leak. (The EGT is there for a reason!!)
-2.25" piping diameter - optimal for upgraded turbos
-includes OE style gaskets (from same factory as OEM gaskets)
Helix Oil Catch Can - Universal $75 shipped !
The Helix Catch Can is designed to trap oil moisture and blow-by caused by normal engine operation, especially in turbo charged vehicles. On your factory vehicle, because of emissions regulations, the waste oil and sludge is generally re-routed back into the intake stream. This debris will tend to accumulate inside the intake tract, intercooler, turbocharger, as well as be ingested into the engine during normal combusion process. Needless to say, this sludge and blow-by will hurt the performance of your vehicle. The Helix Catch Can eliminates this problem by trapping such debris and insuring optimal horsepower and longevity of you vehicle.
Features: Machined and polished aluminum tank, Clear braided hoses with hose clamps and adapter, visual debris level indicator, mounts vertically or horizontally.
Helix Catback - 02+ WRX $499 shipped !
Helix Exhaust
Type: Cat-back (USDM)
Piping Style: AVG 80mm Stainless Mandrel Bent, Polished
Tip Type: 120mm Straight Cut
Resonator: One
Silencer: Yes (included)
Helix (Stainless) - US Spec - 02+ WRX/STI + Free CEL fix $285 shipped !
The Helix Downpipe is the optimal downpipe for the performance minded Suby owner. This downpipe features a cast bellmouth which provides the absolute maximum exhaust flow and minimum back pressure by allowing the wastegate gases to exit without disrupting normal exhaust flow. The piping is full 3" Stainless Steel (304) polished, and the package includes gaskets & bolts. This downpipe replaces both cats and is designed for USDM fitment only. The combination of the Helix uppipe, downpipe, and exhaust system will yield 30+whp!
Helix High-Flow Catted Downpipe (200 cell) 02+ WRX / STI + Free CEL Fix
$SOLD OUT !
The Helix Catted Downpipe incorporates Helix Power’s first-rate bell-mouth downpipe, with the addition of a 200 cell Metal-Substrate high-flow catalytic converter and thermal barrier heat-shield. The 200 cell Metal-Substrate downpipe has been tested by us to yield 7-10whp over the factory twin cats, while able to pass stringent California smog standards on the WRX / STI. The thermal barrier heat-shield assists in rapid warm-up of the cat for maximum efficiency and helping to reduce engine bay temperatures.
Order online or over the phone.
Regards,
Preston
Gruppe-S Engineering
Phone: (510) 783-5300
Gruppe-S is offline
Old 01-05-2005, 07:43 PM   #2
finnRex
A. Moderator
Member Sales Rating: (6)
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Bump for a wicked product. Helix catted downpipe=beautiful
Mika
finnRex is offline
Old 01-06-2005, 07:31 PM   #3
tinger00
Member Sales Rating: (2)
Member#: 42878
04 Forester 2.5x
03 WRX wagon R.I.P.
bumpity bump
tinger00 is offline
Old 01-07-2005, 12:17 AM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks guys. Plenty of headers back in stock too
The headers are great for higher power cars, especially 2.5 STIs
Thanks,
Gary
Gruppe-S is offline
Old 01-10-2005, 05:19 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Monday bump
Thanks
Preston
Gruppe-S is offline
Old 01-10-2005, 06:29 PM   #6
Drews_WRX
Member Sales Rating: (3)
Member#: 20354
2005 SRT-4
POS Mopar stage 2
got a good inside pic of the 4-1 cast collector?
Drews_WRX is offline
Old 01-10-2005, 06:48 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
It's like this but not jet coated.
Thanks
Preston
Gruppe-S
Gruppe-S is offline
Old 01-11-2005, 03:41 AM   #8
casualsurfer
Member#: 60773
2004 WRX
what's the difference between 4-1 and 4-2-1 headers?
casualsurfer is offline
Old 01-11-2005, 03:00 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Usually, 4-2-1 headers are equal length like the Cusco headers.
Our Gruppe-S V2 headers are unequal length.
Thanks
Preston
Gruppe-S
Gruppe-S is offline
Old 01-12-2005, 03:38 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Plenty available
Thanks
Preston
Gruppe-S
Gruppe-S is offline
Old 01-12-2005, 03:44 PM   #11
HIHO_Silver
Member#: 77716
2004 '04 WRX
Silver, of course
When will you have the Helix Catted Dp back in stock and will this dp bolt to the stock catback?
HIHO_Silver is offline
Old 01-12-2005, 05:04 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi, we expect to get more in 2-3 weeks and yes it will bolt to the stock catback.
Thanks
Preston
Gruppe-S is offline
Old 01-15-2005, 02:54 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
bump
Thanks
Preston
Gruppe-S is offline
Old 01-17-2005, 09:02 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Monday bump
Thanks
Preston
Gruppe-S is offline
Old 01-17-2005, 10:05 PM   #15
antimullet
Member Sales Rating: (4)
Member#: 44193
2008 WRX STi
Is the helix catback a full three inch exhaust? FIts the STi with a helix catted dp no problem?
antimullet is offline
Old 01-18-2005, 01:54 AM   #16
soundwave
Member Sales Rating: (1)
Member#: 30370
2011 STi
White & Hyperblue
Yup, it's a full 3" and fits the Helix catted DP
soundwave is offline
Old 01-19-2005, 01:28 AM   #17
JOJO GT 99
Member#: 59732
99 GT
Send PM .
JOJO GT 99 is offline
Closed Thread
CA FS: Gruppe-S v2 Headers & Cobb v1 AP FWD WRX Engine/Power/Exhaust 1 06-12-2008 12:17 AM
Helix Cams back in stock - $519 Shipped! STi Mounts! Cobb APs in stock! Helix DPs! Gruppe-S Engine/Power/Exhaust 3 07-31-2006 06:59 PM
STi Helix Injectors back in stock! Helix Cams for EJ20, built motors, much more! Gruppe-S Engine/Power/Exhaust 32 02-09-2006 04:00 PM
Crazy Helix Downpipe Sale! Helix Uppipes Back in Stock ! Gruppe-S Engine/Power/Exhaust 17 01-10-2006 07:57 PM
Sti V6 Ra Gearsets And Components Back In Stock!!! Gruppe-S Drivetrain 34 01-15-2005 02:58 PM
