Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 01-05-2005, 06:48 PM   #1
superhero
Member#: 32153
2006 300C
crappy blue
Default stiffer than expected?
was changing brake fluid and had one jackstand 1/2 inch lower than the other 3 - the frame didn't budge... didn't touch the jackstand at all...
the frame was stiffer than I expected
superhero is offline   Reply With Quote
Old 01-05-2005, 07:58 PM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
My 04 Wagon is the same way. It rests on 3 jackstands, not 4. I wouldn't know this if my buddy's garage wasn't so uneven though.
Old 01-05-2005, 09:38 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...yeah....you can rotate both tires on one side just by just jacking up the front.....
Old 01-05-2005, 10:01 PM   #4
rick-l
Member#: 33868
2003 wrx
srp
maybe that's why they tell you not to use 4 jackstands. The unloaded end will push over sideways.
rick-l is offline   Reply With Quote
Old 01-05-2005, 11:04 PM   #5
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Mike Wevrick is offline   Reply With Quote
Old 01-05-2005, 11:25 PM   #6
rick-l
Member#: 33868
2003 wrx
srp
Originally Posted by Mike Wevrick
I bought some jackstands from sears (6 ton). It had a sticker on it that said do not work under the car when supported by 4 jackstands.
I couldn't figure out why.
It could be because four jackstands is really only three (see above) and the one that supports one end of the car could be easily pushed over.
Old 01-05-2005, 11:29 PM   #7
nick04263
Member#: 68799
2004 WRX COBB STG 2+
I work under my car all the time using 4 jack stands. I even push against the car to confirm it won't budge.
nick04263 is offline   Reply With Quote
Old 01-06-2005, 02:17 AM   #8
superhero
Member#: 32153
2006 300C
crappy blue
so you're only supposed to use 3 jackstands and then work under the car - got it
Old 01-06-2005, 04:27 PM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
dude, have you tried to topple a properly used jackstand?
ain't gonna happen very easily!
Old 01-06-2005, 11:31 PM   #10
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Every car that I've rotated the tires on, all I had to do was jack the car up on the side for both wheels. I don't think our Suby's are that "special."
-Charles-
ImprezaVA is offline   Reply With Quote
Old 01-06-2005, 11:31 PM   #11
leecea
Member#: 37359
2003 WRX
I think this came up before and someone suggested that it was because people might not get the car up on all 4 correctly. For example, if the front is on stands and you jack up the rear without letting the jack roll, it can pull the front stands over onto two legs and make them unstable.
leecea is offline   Reply With Quote
Old 01-07-2005, 01:00 PM   #12
superhero
Member#: 32153
2006 300C
crappy blue
-Charles-
I agree - the subies are not special... I think most cars would do the same thing.
later
daniel
02 WRX wagon 4EAT springs, stiffer than your springs GTScoob Suspension/Brakes/Handling 2 04-12-2007 12:29 PM
my sti shifter notchier and stiffer than others Focus4 Transmission (AT/MT) & Driveline 2 02-26-2005 07:02 AM
05 wrx stiffer than 03 wrx? Blue_Rexer General Community 13 11-23-2004 10:38 AM
Ok.. is a whiteline RSB stiffer than my Cusco? JonnySubaru Brakes, Steering & Suspension 9 06-26-2003 02:54 AM
