Old 01-05-2005, 07:49 PM   #1
Lancer3d
Member#: 59103
2003 WRX
GunMetal
Default What gear to log
I was just wondering if I am having problems with knocking, what gear should I log the UTEC so I can get opinions from other members?? Also, no matter how I adjust the ABC from Utec, my boost levels stays the same even when I made adjustments to the boost level map. Can someone please help me??
Lancer3d is offline   Reply With Quote
Old 01-05-2005, 08:08 PM   #2
rich728
Member#: 40328
2004 WRX STi
BSP #728
what car?
rich728 is offline   Reply With Quote
Old 01-05-2005, 08:16 PM   #3
Lancer3d
Member#: 59103
2003 WRX
GunMetal
I have a 03 WRX with UTEC verion 5, and 2.4b software version.
My mods are Genie uppipe, 3" downpipe, 3" catback.
Thanks
Old 01-05-2005, 10:10 PM   #4
CMJ
Member#: 39235
3rd.
CMJ is offline   Reply With Quote
Old 01-05-2005, 10:13 PM   #5
Lancer3d
Member#: 59103
2003 WRX
GunMetal
I just made 2 more runs, this is my results:
2596, +5.3,3.0,101, 40, 00, rich,+15.4, 25.0,+19.2, +0.3,105.00,3.0
2620, +6.2,3.1,101, 40, 00, rich,+14.3, 29.0,+18.8, +1.0,105.00,3.1
2741, +7.6,3.2,100, 50, 00, rich,+12.5, 34.0,+18.0, +1.5,105.00,3.3
2832, +8.8,3.3,101, 60, 00, rich,+11.3, 41.0,+17.5, +1.5,105.00,3.4
2960,+10.2,3.4,100, 70, 00, rich,+11.1, 46.0,+17.2, +1.5,105.00,3.6
3077,+12.3,3.6,100, 80, 00, rich,+11.0, 51.0,+17.0, +1.5,105.00,3.6
3132,+14.1,3.6,101, 90, 00, rich,+11.0, 55.0,+17.0, +1.5,105.00,3.6
3258,+15.9,3.6,101,100, 00, rich,+11.0, 58.0,+17.0, +1.5,105.00,3.8
3408,+17.4,3.7,100,100, 00, rich,+10.5, 61.0,+17.0, +1.5,105.00,3.7
3534,+18.0,3.7,100,100, 00, rich,+10.2, 65.0,+17.0, +1.5,105.00,3.8
3716,+17.8,3.8,101, 90, 01, rich, +8.2, 70.0, +9.0, +1.5,105.00,3.8
3775,+17.8,3.8,100, 90, 00, rich, +8.9, 73.0, +9.6, +1.6,105.00,3.9
3875,+17.4,3.9,100,100, 00, rich, +9.6, 75.0,+10.2, +1.6,105.00,3.9
4006,+17.4,3.9,100, 90, 00, rich,+10.9, 78.0,+11.7, +2.0,110.00,3.9
4065,+17.6,3.8,100, 90, 00, rich,+11.1, 82.0,+20.0, +2.0,110.00,4.0
4257,+17.0,4.0,100, 90, 00, rich,+10.6, 87.0,+20.0, +2.0,110.00,4.0
4312,+16.8,4.0,100, 90, 03, rich, +8.3, 90.0,+12.8, +2.0,110.00,4.1
4504,+16.6,4.0,100, 90, 00, rich, +7.9, 95.0,+14.0, +1.5,115.00,4.1
4616,+16.1,4.1,101, 90, 00, rich, +8.5, 96.0,+14.4, +1.7,115.00,4.1
4655,+16.6,4.1,100, 90, 00, rich, +8.8, 97.0,+15.0, -0.4,115.00,4.0
4916,+16.6,4.1,100, 90, 00, rich, +9.5, 94.0,+23.7, +1.0,115.00,4.1
4930,+16.6,4.1,100, 90, 16, rich, +6.8, 94.0,+15.7, +0.4,115.00,4.1
5065,+16.1,4.1, 99, 80, 00, rich, +7.9, 94.0,+15.9, -0.6,120.00,4.1
5065,+15.7,4.2,100, 80, 00, rich, +7.8, 96.0,+16.0, -0.6,120.00,4.1
5184,+15.1,4.2,100, 80, 00, rich,+10.0, 98.0,+24.0, -0.6,120.00,4.1
5144,+12.9,3.8, 2, 00, 11, rich, +8.5, 71.0,ECU. , +0.0,ECU. ,3.7
2485, +5.1,3.0,101, 40, 00, rich,+15.4, 24.0,+19.6, +0.1,105.00,3.0
2587, +5.9,3.0,101, 40, 00, rich,+15.0, 26.0,+19.2, +0.6,105.00,3.0
2675, +6.8,3.1,101, 40, 00, rich,+14.4, 30.0,+18.8, +0.7,105.00,3.1
2748, +8.0,3.2,101, 50, 00, rich,+12.2, 35.0,+17.9, +1.5,105.00,3.2
2849, +9.0,3.2,101, 60, 00, rich,+11.7, 39.0,+17.7, +1.5,105.00,3.4
2939,+10.4,3.3,100, 70, 00, rich,+11.1, 43.0,+17.4, +1.5,105.00,3.5
3003,+12.1,3.5,100, 80, 00, rich,+11.1, 47.0,+17.0, +1.5,105.00,3.5
3086,+13.5,3.5,100, 80, 00, rich,+10.9, 50.0,+17.0, +1.5,105.00,3.6
3195,+14.7,3.5,101, 80, 00, rich,+10.8, 52.0,+17.0, +1.5,105.00,3.6
3271,+15.3,3.6,100, 80, 00, rich,+10.5, 54.0,+17.0, +1.5,105.00,3.6
3432,+15.5,3.7,101, 80, 00, rich,+10.4, 57.0,+17.0, +1.5,105.00,3.7
3505,+15.5,3.7,100, 80, 00, rich,+10.0, 61.0,+17.0, +1.5,105.00,3.7
3611,+15.5,3.7,101, 80, 00, rich, +9.6, 64.0,+17.0, +1.5,105.00,3.7
3711,+15.5,3.7,100, 80, 00, rich,+10.5, 66.0,+17.0, +1.9,105.00,3.8
3779,+15.3,3.8,100, 80, 00, rich,+11.4, 69.0,+17.6, +1.5,105.00,3.8
3912,+15.7,3.7,101, 80, 00, rich,+12.4, 71.0,+18.8, +1.8,105.00,3.8
3958,+15.9,3.8,100, 90, 00, rich,+13.2, 73.0,+20.0, +2.0,110.00,3.8
4084,+16.1,3.9,100, 90, 00, rich,+13.1, 78.0,+20.0, +2.0,110.00,3.9
4177,+16.4,3.9,100, 90, 00, rich,+13.2, 83.0,+20.0, +2.0,110.00,4.0
4295,+15.9,3.9,100, 80, 00, rich,+12.9, 85.0,+20.6, +2.0,110.00,4.0
4450,+15.3,3.9,100, 80, 00, rich,+12.1, 88.0,+21.0, +1.8,110.00,4.0
4547,+15.3,4.0,100, 80, 00, rich,+12.6, 90.0,+22.3, +1.7,115.00,4.0
4585,+15.7,4.0,101, 90, 00, rich,+13.0, 91.0,+22.4, +1.6,115.00,4.0
4782,+15.7,4.0,100, 90, 00, rich,+13.1, 93.0,+22.9, +1.4,115.00,4.0
4796,+15.7,4.0,100, 80, 00, rich,+13.4, 91.0,+23.2, +1.2,115.00,4.0
4880,+15.3,4.0,100, 80, 00, rich,+14.8, 93.0,+23.4, -0.2,115.00,4.1
5042,+15.1,4.1,100, 80, 00, rich,+11.9, 90.0,+24.0, -0.6,120.00,4.0
5042,+15.3,4.1,100, 90, 00, rich,+12.5, 92.0,+24.0, -0.6,120.00,4.0
5120,+14.7,4.1,100, 80, 02, rich, +7.9, 96.0,+16.0, -0.6,120.00,4.1
5316,+15.3,4.1,100, 80, 00, rich, +7.7, 96.0,+16.0, -0.6,120.00,4.1
5274,+15.3,4.1,100, 90, 00, rich, +8.0, 98.0,+16.0, -0.6,120.00,4.1
5482,+15.1,4.2,100, 80, 00, rich, +8.8, 97.0,+24.0, -0.6,120.00,4.1
Any suggestions as to how to get rid of the knock?
Old 01-05-2005, 10:23 PM   #6
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
Yes, reduce your timing. It's also tough to say without seeing wideband A/F ratios, but obviously 20 degrees at 18psi, or 24 degrees at 15psi nearing redline is too much.
You're probably not making more boost because the turbo is tapped out. Stock TD04? I wouldn't expect to be able to get much more than 15psi at redline no matter how much you crank up the boost.
serendipity is offline   Reply With Quote
Old 01-05-2005, 10:25 PM   #7
Lancer3d
Member#: 59103
2003 WRX
GunMetal
Should I just lower the timing at the knock interval or should I lower the boost throughout? It looks like that I did better from the second run than the first run, by looking at the logs. The second run, I lower the boost by 2 turns from the ABC.
Old 01-05-2005, 10:33 PM   #8
serendipity
Member#: 54597
08 'Busa, 08 ML63
I don't know enough about the TD04 on 2 liters to know how much boost they can run before they just heat up the air. 15psi seems like a lot to ask from it. But even if you drop it 2psi throughout, you'll probably still find you need to lower timing. 20-24 degrees is quite a bit. I'd back off the timing first, and maybe see what boost other folks are running from the stock turbo.
Old 01-05-2005, 10:34 PM   #9
Lancer3d
Member#: 59103
2003 WRX
GunMetal
How much degress should I knocck off throught out? or just close to the redline
Old 01-05-2005, 11:04 PM   #10
serendipity
Member#: 54597
08 'Busa, 08 ML63
Right now you have it dipping to 17 degrees at 3000 RPM, and then climbing back up to 24. Focusing on the high load zones, I would have it drop to 15 degrees by 3250 RPM, and slowly climb back up to 20 degrees by redline. In other words, you want smooth transitions, but you don't want to sacrifice power down low (in RPM and load) by knocking off timing everywhere. So take off 3-4 degrees, but make it nice and smooth.
See how that works. If it still knocks, take another degree off up top.
Old 01-06-2005, 01:03 PM   #11
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Your boost control numbers seem either really high or really low. Check to see which type of boost control you are using in the parameters. OLB is 0-100, and CLB is 0-500 for 2.5B.
I'm going to bet you have your boost set to OLB, because your boost is way too high for your setup.
p.s. I have the 2.5B manual if you would like an electronic copy of it.
mbiker97 is offline   Reply With Quote
Old 01-06-2005, 02:35 PM   #12
ejh25
Member#: 65267
Log using 4th because of its high load. If you use a lower gear you may get overboosting and knock in 4th or 5th.
ejh25 is offline   Reply With Quote
Old 01-06-2005, 03:52 PM   #13
serendipity
Member#: 54597
08 'Busa, 08 ML63
Not necessarily. He said he's using the ABC - so his boost values may be relatively low for the amount of boost he's running.
My CLB values are 150 for 20psi or so with a serial MBC.
scored a free laptop,whats needed to log runs nation1979 Newbies & FAQs 7 02-15-2009 11:54 PM
What gears to go with? cons80 Transmission (AT/MT) & Driveline 8 08-20-2008 11:44 AM
What Parameters to Log to Check Car is Running Properly ? Murf_68 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-07-2007 08:45 AM
First time skiing. What gear to buy and where to buy it? plunk10 Mid Atlantic Impreza Club -- MAIC 14 12-19-2003 10:32 PM
What gear to finish 1/4 mile in stock WRX? Drews_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-14-2002 12:02 AM
