Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Go Back   NASIOC > NASIOC Subaru Models > Impreza Forum > Impreza (1993 - 2001)
Old 07-08-2001, 03:22 PM   #1
NYEJ25
Member#: 1876
Question Ned wiring diagram for AFC
I need a wiring diagram, and install instructions for an AFC on a 2000 RS. I got it last night,a nd need to know what to wire where and how to set it up. Also if anyone has a setting for me for a 2000 RS with intake and exhust.
Thanks
Drew
NYEJ25 is offline   Reply With Quote
Old 07-08-2001, 03:46 PM   #2
JGard
Pooptastic
Member#: 1904
2009 WRX Premium 5dr
1991 Mazda Miata
go to www.forcefed4.com and follow the links 2.5RS, FAQ, and all the wiring diagrams are there.
JGard is offline   Reply With Quote
Old 07-08-2001, 04:10 PM   #3
NYEJ25
Member#: 1876
Thanks for the info. how hard is it to set up, and tune. If I screw up on the tuning is there away to set everything back to stock? How hard is it to install for a person with some mechanical skills? How long does the whole process take from start to finish?
Thanks
Drew
Old 07-08-2001, 04:24 PM   #4
JGard
Pooptastic
Member#: 1904
1991 Mazda Miata
i just did it... it's pretty easy, but i've dealt with the ECU before.
you need either an EGT or A/F gauge in order to tune it. You can, however, keep it at 0.0% correction, and that'll be same as stock.
Once you get the gauges, it won't take too long to tune. btw, do you have an intake or anything installed? if the car is otherwise stock, there's probably no purpose in tuning an AFC.
Old 07-08-2001, 05:17 PM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I did it less than one hour. Here is the installation:
http://www.geocities.com/matsut_rpi00
Make sure to use a soldering gun or something really good to connect the wires together.
If you screw up the tuning, you can reset / recalibrate the SAFC to run the car with the stock ECU program.
tmat3 is offline   Reply With Quote
Old 07-09-2001, 08:04 AM   #6
NYEJ25
Member#: 1876
Thanks to everyone for your help. After some careful thought I am going to have it done by a local speed shop. They can also tune in for me as well.
Thanks again
Drew
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 05:42 AM.
