Old 01-05-2005, 08:13 PM   #1
STi-Nismo Dood
Member#: 4149
MY93 ImprezaRA Sedan
GC8.6 Aspen White
Default What is my new compression ratio? EJ18 heads w/ EJ20 block
my motor is being hybrid'd with a 2003 ej20 shortblock thats going w/ my 1993 phase-I ej18s sohc head.
What would be my compression ratio if I am using regular ej20 head gaskets on this? Thanks.
STi-Nismo Dood is offline   Reply With Quote
Old 01-08-2005, 05:23 PM   #2
STi-Nismo Dood
Member#: 4149
GC8.6 Aspen White
ehhhhh does anyone know if the heads on the ej18 are the same as the NA ej22's??
What is your build compression ratio? Kosmic Built Motor Discussion 36 07-24-2007 03:07 PM
What is my new AR Fab motor capable of? List of mods inside moorebl Built Motor Discussion 13 06-30-2007 09:35 AM
What is my compression ratio? powerlabs Subaru Conversions 1 02-23-2006 02:06 PM
What is the stock compression ratio for the 99-01 RS? WRC1 Normally Aspirated Powertrain 7 06-08-2004 07:27 PM
What is the correct compression ratio for the WRX myko011 Factory 2.0L Turbo Powertrain 1 09-12-2001 05:57 PM
Message Board Statistics All times are GMT -4. The time now is 12:45 AM.
