Old 01-05-2005, 08:31 PM   #1
RezaREX
Member#: 22021
2002 Impreza WRX
Default Battery Recharge??
I'm curious as to how long it would take the stock alt on a 02 WRX to charge a completely drained Optima yellow top. I'm thinking of running my stereo(or parts of it) off a separate deep cycle battery then recharging it when it has completely drained using some kind of isolator switch. Second question would be how long would the optima last on a 1300 watt RMS system??(obviously there are variables here but assuming the volume is relatively high)
RezaREX is offline   Reply With Quote
Old 01-05-2005, 08:47 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If it's completely drained you need to remove it from the car and hook it up to an external charger. It would take a long time to fully recharge it just driving around.
No way to tell for sure how long it will run your system, since the current draw is dynamic. You can take an educated guess based on the reserve rating of the battery and the combined nominal current ratings of your equipment. It would also be a good idea to have a voltmeter hooked up so you can tell when the battery is drained and shut things down.
The stock alternator does not have enough capacity to run two batteries even with an isolator.
Braille Battery Rechargable? Godspeed55 Interior & Exterior Modification 14 01-30-2010 04:31 AM
Rechargeable batteries recall for iBook G4 and PowerBook G4 docwhorocks Off-Topic 0 05-23-2005 03:21 PM
Best Digi batterys. Best rechargeable? mmmprza Off-Topic 15 02-05-2004 02:21 PM
Battery recharger? Soon2bSubbieowner Mid Atlantic Impreza Club -- MAIC 2 09-07-2003 07:37 AM
Can you recharge a 12 volt motorcycle battery with a 12 volt car charger? Cjchaps Electrical & Lighting 3 07-01-2003 01:55 PM
