Old 01-05-2005, 11:01 PM   #1
Lancer3d
Member#: 59103
2003 WRX
GunMetal
Default Utec upgrade problem!!!! Please Help!!!!
I tried to upgrade the Utec version from 2.5b to version 4.2 but when it tries to verfy the update file, it saids wrong ID code, does anyone know what's wrong?
Lancer3d is offline   Reply With Quote
Old 01-06-2005, 01:43 PM   #2
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
did you follow the upgrad directions? Did you have the switch set in the right position on the utec or the jumpers set up right (depends on version)? Do you have the latest version of the utec flash programmer? Get the 4.2 software again and make sure it's correct (not a corrupt file) Then try to load it all again...
I have never seen that error before so I'm just trying to rule out all the likely causes of version upgrade failure. If you repeat the above steps and noone else has any idea contact TXS let them know what you did and they'll help you.
MustGoFast is offline   Reply With Quote
Old 01-06-2005, 01:50 PM   #3
spoolin1
Member#: 50541
2001 Is300- Sold WRX
MSM
i have a question...since i have a version 3.1, will i need to upgrade to a 4.2c from the site?
spoolin1 is offline   Reply With Quote
Old 01-06-2005, 04:15 PM   #4
TurboXS (Pete)
Member#: 16704
In the flash program go to the "Options" menu. Click on the "Change ID Code". Make sure that the code is set to all zeros by clicking on "Zero".
However this number should not normally have been changed so something else may be happenning.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
My brake upgrade issue. Please help emsmap Newbies & FAQs 8 09-07-2008 06:15 PM
firmware upgrade failed, please help AndrewSTi UTEC 2 02-03-2008 03:58 PM
Major Utec Problems, Please Help! rexmobbin' Engine Management & Tuning 9 12-16-2003 10:39 PM
UTEC or Piping...Please help! Dub you are ex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-29-2002 12:26 PM
