Old 01-06-2005, 12:59 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default clutch and flywheel what works with what?!?!
so FWD flywheels are different from AWD flywheels right? are you able to use a AWD for a FWD car? does this mean you'll need a AWD clutch ? I have a JDM EJ20G clutch and flywheel. would this set up work in a FWD impreza? what throw out bearing should be used? if it even works...
scobaru is offline   Reply With Quote
Old 01-06-2005, 09:23 AM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Negative.
One major difference; the input shaft or whatever that the TO bearing goes over. The FWD one has a smaller diameter, so you wouldn't be able to use the AWD clutch disk, and then the FWD clutch disk has a smaller diameter.
Brent
scoobyimprza is offline   Reply With Quote
Old 01-06-2005, 09:37 AM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
so wait... if the input shalf is smaller how is an AWD clutch disc would be able to fit over the input shalf?
so couldn't you use an AWD flywheel along the clutch with just the FWD throw out bearing?
Old 01-06-2005, 09:43 AM   #4
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Sorry, I should have been more specific.
The part of the shaft with the teeth that slide into the clutch disc, that is also smaller.
Old 01-06-2005, 10:51 AM   #5
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
yah when you first said this I thought you ment that but you made this comment
Negative.
One major difference; the input shaft or whatever that the TO bearing goes over. The FWD one has a smaller diameter, so you would be able to use the AWD clutch disk, and then the FWD clutch disk has a smaller diameter.
Brent
the clutch disc has the teeth on it unless your talking about the pressure plate?
Old 01-06-2005, 11:41 AM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Sorry, I meant to say wouldn't. I'll edit that.
Old 01-06-2005, 05:24 PM   #7
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
so if this is the case is it possible to use the AWD flywheel with the AWD clutch and the FWD throw out bearing and friction disc?
Old 01-06-2005, 05:52 PM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
No, the piece in the center of the clutch with the teeth is a different size between the FWD and AWD.
Old 01-06-2005, 06:33 PM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I know this but the only thing that teeth in the middle affects is the friction disc the pressure plate has nothing to do with the those teeth
Old 01-06-2005, 06:35 PM   #10
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Yeah, but the disks have a different diameter because the pressure plates also cover a different area, so one disk won't work with the other pressure plate.
Old 01-06-2005, 10:21 PM   #11
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Clutches are cheap, get the right parts... as much fun as tearing the transmission back out again is...
Baja Turbos: What works with What? honda killer Baja Forum 242 04-15-2016 03:08 AM
PLEASE HELP clutch and flywheel combo not working jeff863 Transmission (AT/MT) & Driveline 17 03-03-2010 11:05 AM
What Clutch and Flywheel if necesary Works Transmission (AT/MT) & Driveline 3 05-19-2004 03:29 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
