Old 01-06-2005, 02:17 AM   #1
subimp6u08
Member#: 15440
2015 STi
Default my car won't start
ok...here's what happened.
I wanted to paint the foglight switch to red, so i opened up and colored the bulbs. then i closed it, but the foglight switch light won't come on, so
I thought something was wrong with wiring, and as soon as I touched the purple and yellow/green wires from foglight wiring harness, the fuse just went off. then this weird noise started to come out fromt the engine bay, I tried to find any other blown fuses, but I could't find any other than the illumination fuse. the noise only made when I turned on the headlights, after few tried, the headlights won't come on, and the car won't even start.
what's the problem here? I can't even tow this car to the dealer, since
the car is in the apartment garage. please anyone help~!!!
subimp6u08 is offline   Reply With Quote
Old 01-06-2005, 03:46 AM   #2
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
charge battery
00Maddog is offline   Reply With Quote
Old 01-06-2005, 04:01 AM   #3
subimp6u08
Member#: 15440
2015 STi
the battery's not the issue, because everything works
it makes buzz noise when the electricity is on
Old 01-06-2005, 09:55 AM   #4
bullseye17
Member#: 16661
1997 Outback
Green
check the main fuse in the fuse box under the hood, it has two nuts holding it on, and you are going to have to go to the dealer for a new one.
bullseye17 is offline   Reply With Quote
Old 01-07-2005, 08:21 AM   #5
bullseye17
Member#: 16661
1997 Outback
Green
any luck?
OT CAR PEOPLE (suprisingy few of you) My car won't start Oh Canada Off-Topic 76 10-06-2005 05:19 PM
Oh Man - My car won't start! BJamerican Legacy Forum 8 02-01-2002 09:52 AM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-11-2001 11:35 PM
My Car Won't Start!!!!! andyC Normally Aspirated Powertrain 12 09-05-2001 01:22 AM
('93-'01) my car won't start chinaman Impreza Forum 3 05-21-2001 06:54 PM
