Old 01-06-2005, 02:47 AM   #1
casualsurfer
Member#: 60773
2004 WRX
Default Is there an ideal A/F ratio for ALL RPM range?
I was just wondering if there was an ideal A/F ratio throughout the RPM range or it depends on what RPM you're running. If it depends, anyone have any idea what that would be in 100RPM increments?
casualsurfer is offline   Reply With Quote
Old 01-06-2005, 07:29 AM   #2
happasaiyan
Member#: 37731
no.
there is an ideal AFR CURVE for a particular engine setup...outside of that, the AFRs vary between load sites, amount of boost, rpm, TPS, etc.
look up micks tuning guide or download turboxs' manual for the utec. thats a good place to start.
happasaiyan is offline   Reply With Quote
Old 01-06-2005, 09:55 AM   #3
hippy
Member#: 36528
2002 Impreza Wrx
Bosche seems to think that most engines make most power between 12.5 and 14 to 1 a/f ratio(on gas)...... If an engine's running richer then 12.5 to 1, ya know that more power could probably be made by leaning the a/f ratio out to 12.5 to 1. The problem is that many(if not most of us) of us can't do that for one reason or another(like being octane limited or whatever)), and we're stuck with a/f ratios which are richer then what's ideal.
peace
Old 01-06-2005, 10:17 AM   #4
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
It's really boost or no boost not rpm.
mbiker97 is offline   Reply With Quote
Old 01-06-2005, 11:23 AM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
At zero load, or minimal load (I.E. cruising) you'd probobly want to maintain stoichimetric for the majority of the RPM range, with an enrichment >4k for example.
As load changes, an ideal AFR range will change, through out the RPM range.
So if you HAD to have one solid AFR from 1-7k rpm, I'd say it have to be done 3 dimensionally
AFRxRPMxLOAD.
That's about the only way you'd safely get away with it.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 01-06-2005, 04:44 PM   #6
bboy
Member#: 56468
04 Improved STI
Dirty White
deja vu, all over again
This covers the basics pretty well. The guy is probably a member of NASIOC. Figure 3.8 is the classic AFR figure:
http://www.hss.cmu.edu/philosophy/pr...ang_thesis.pdf
This deals more with timing and what MBT really means, excellent paper:
http://www.visteon.com/utils/whitepa...03_01_3266.pdf
Another good AFR/Timing read is here. It also has some fundamental links. I believe this piece was written by NASIOC member SaabTuner:
http://www.saabscene.co.uk/ubb/ultim...c/23/1194.html
loud knock from block, all rpm range, all the time. Quix Service & Maintenance 6 07-16-2007 08:08 PM
Ok so i have everything to tune with, what is an ideal A/F ratio? GregBolby Engine Management & Tuning 6 03-07-2005 11:01 PM
what is an ideal air fuel mixture for a WRX? Homemade WRX Engine Management & Tuning 58 03-23-2004 09:59 PM
Is there an agreed upon best replacement for re92s? Rev Tire & Wheel 4 10-05-2003 09:16 PM
Where is/ or is there an idle adjustment screw for 02' Wrx? PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-14-2003 06:19 PM
