Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-06-2005, 04:15 AM   #1
chaddeus
Member#: 56624
2004 Subaru WRX STi
Default Projector Xenon Retrofit on 04 STi Please
I know a number of STi owners had retrofit their headlights with the Projector Xenon. Previously from BMW Projector Xenon, I really miss those days.
Now, I would like to have it on my STi and I was wondering if anyone would be able to help me out. I am an idiot when it comes to electrical stuff so a big help would be great
- Charles
chaddeus is offline   Reply With Quote
Old 01-06-2005, 09:16 AM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
You may want to check this thread as there are some posts and pics about a projector retrofit on the '04 lights:
http://forums.nasioc.com/forums/show...=projector+STi
And here's a link to hidtech.com and retrofits:
http://hidtech.com/projects/projects.html
Hank3 is offline   Reply With Quote
Old 01-07-2005, 08:05 PM   #3
chaddeus
Member#: 56624
2004 Subaru WRX STi
Hi Charles,
Thanks for your inquiry. We will need you to send us your headlights for
retrofitting. The whole process would take 2-4 business days depends on our
word load. However it may take up to 7-10 business days. Some project we
need to do it slowly and little by little each day to ensure highest
quarlity.
Also we can only use your existing HID ballasts, your HID D2R bulbs is not
good for projector.
Following is a breakdown for this project:
$175 Hella HID xenon projectors (brand new parts with warranty)
$100 Philips 85122 HID D2S bulbs (brand new parts with warranty)
$300 Rretrofit customization cost (most Japanese and German import)
$150 Type S projector enclosure (please check
http://hidtech.com/images/02171.jpg and
http://hidtech.com/projects/04accord.html)
$50 Return shipping and handling within the US
Let us know if you have any more questions.
Sean
HIDtech
Old 01-07-2005, 08:51 PM   #4
V6
Member#: 2703
Y2K GC8
Silver forever
Just curious, anyone tried to do the mods on the old school GC8 headlights?
I would like to see the result good or not.
V6 is offline   Reply With Quote
Old 01-08-2005, 12:16 AM   #5
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Iirc, you're talking about a my1995~1996 GC, correct? Even if someone with a my2000+ GC gets a good result, it may differ a bit with the older healdight because it has the fluted lens design that is supposed to work with the parabolic reflector. I wouldn't be surprised if you encounter a lot of diffuse output with the HID retrofit, even if the HID unit is an entire projector unit and not just the HID-to-Halogen mount retrofit.
You may be better off purchasing those Morette replicas and mount the Xenon projectors there than putting them behind the fluted lens imho.
my 2 cents.
satrya is offline   Reply With Quote
Old 01-08-2005, 12:38 AM   #6
V6
Member#: 2703
Y2K GC8
Silver forever
Since the MY99+ the headlight changed from fluted lens into clear lens, that's why I am wondering what will be the outcome.
Old 01-08-2005, 12:59 AM   #7
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
My mistake. In spite of the car in your profile, I thought I saw a post in the past where you inquired about the older GC headlights. I suppose it was a different person.
If the mounting of the Xenon unit is properly done, then I don't see how the clear lens headlight housing of the newer GC will pose a different problem than a similar retrofit on a GD. Any cosmetic evidence of the transplant can probably be easily hidden by putting the Xenon trim rings/bezel around them imho. Heat and lens discoloration due to UV are probably of no concern either.
Iirc, I've only seen Xenon & BiXenon retrofits on the bugeye and crosseye Imprezas here in Nasioc. Maybe you can be the first to experiment on a GC
Old 01-09-2005, 05:14 PM   #8
dithergizzard
Member#: 58232
- Charles
There are also a couple of related links in the HID sticky at the top of this forum you may be interested in. Look around the middle of my first post there.
dithergizzard is offline   Reply With Quote
Old 01-14-2005, 03:32 PM   #9
clamdip
Member#: 18709
would i also be able to do these on the 02-03 jdm projector lights? i wanted to make the turn signal into something like a projector high-beam or even a fog light. i don't know, i'm soooo bored i sometimes think of these little projects to keep myself busy. any thoughts? suggestions? flames?
clamdip is offline   Reply With Quote
04 STI please read my misfire log bstoehr83 Open Source Reflashes 0 10-20-2009 10:23 PM
Need Brakes! 04 STI Please help SBPhilly Brakes, Steering & Suspension 6 06-30-2008 09:01 PM
X5 projector on 04 sti... 80884 Electrical & Lighting 4 10-24-2006 11:15 PM
Will these wheels fit the 04 STI -- Please Reply crzhog Tire & Wheel 3 02-17-2006 11:33 AM
Projector Beam Replacements for 04 STi? essogas Interior & Exterior Modification 4 09-04-2005 11:43 PM
