Alaskan Impreza Club
Old 01-06-2005, 12:34 PM   #1
wrxzolli
Member#: 69081
2004 WRX
World Rally Blue
Subaru Stars Traction vs. weight?
This is a question about planning for the winter rally cross on the 15th. What do you guys think about weight vs. traction? Do you think it better to leave a heavy subwoofer box (70 lbs) over the rear wheels for traction? Or remove it for less weight? This is definitely not a 1/4 mile run! Any thoughts?
wrxzolli is offline   Reply With Quote
Old 01-06-2005, 01:16 PM   #2
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
If it is not bolted in, then the tech inspector will probably make you remove it anyways.
RallyX13 is offline   Reply With Quote
Old 01-06-2005, 01:50 PM   #3
wrxzolli
Member#: 69081
2004 WRX
World Rally Blue
It's crammed and strapped in very tightly.
Old 01-06-2005, 05:21 PM   #4
MGAMAN
Member#: 24671
2010 Audi S4 PP
2006 R1 - 06/08 hybrid
I would remove it simply because it wont add that much actual traction in snow and ice, it will just pre-load the suspension in the rear more, and take away from effective suspension travel. If its weight will be actually felt, it will be in the extra dead mass causing more intertia in the rear, thus, you'll subtly be fighting against extra sliding. Its like pushing a glass with some water in it, after it stops the extra mass causes it to slide a bit more than it would have without it. And like RallyX13 said, it will probably be flagged by a tech inspector, and you'll hafta remove it anyways. Personally, I dont like the extra weight in my car no matter what the driving conditions. In any form of racing, lighter is always better. The only time they add weight is when the exceed the minimum weight requirements.
MGAMAN is offline   Reply With Quote
Old 01-06-2005, 07:41 PM   #5
shortfuseWRX
Member#: 38573
1997 toyota tacoma
Black death
meh WOT is WOT hahaha
wont matter how much weight or traction you have then
sam
shortfuseWRX is offline   Reply With Quote
Old 01-07-2005, 06:51 AM   #6
NikFu S.
Member#: 78982
1992 NFSVX LSL 5mtGT
Long name, short temper.
70lbs is extreme for a set of subs. My two 12in JLAs are only about 30 even mounted in the box.
Even so it's a very negligible amount of weight.
Also in my experience, a lighter vehicle tends to handle better in low traction conditions provided tires are adequate. The more inertia you build up the harder it is to change velocity.
NikFu S. is offline   Reply With Quote
Old 01-07-2005, 12:53 PM   #7
wrxzolli
Member#: 69081
2004 WRX
World Rally Blue
You haven't seen my sub! The woofer alone weighs 50lbs! Check it:
http://www.jlaudio.com/subwoofers/12w7.html#
Thanks for all the input guys, I'll be taking it out for the rally. The drive up won't be as enjoyable but oh well.
Old 01-07-2005, 07:46 PM   #8
NikFu S.
Member#: 78982
Your sub has more displacement than your Suby...
Old 01-07-2005, 11:23 PM   #9
MGAMAN
Member#: 24671
2010 Audi S4 PP
a glass has more displacement than a 1/4 cup of water, yet it still is affected.........simple phsyics, regardless if its enough mass to add to the actual effective weight of the vehicle than it will, obviously, have an effect, even if minor.
Old 01-07-2005, 11:54 PM   #10
NikFu S.
Member#: 78982
Hard to read that last post but my point was the sub is huge.
Old 01-08-2005, 12:31 AM   #11
02-elite-gettingwrx
Member#: 45650
2015 WRX Limited
Brian quit being such an intellectual asian on us
02-elite-gettingwrx is offline   Reply With Quote
Old 01-08-2005, 02:28 AM   #12
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
I took everything out of my trunk, box, tire, jack, cover, carpet, all but the amp which is bolted down. the less weight in the rear the better so you can slide easier by spinning out at the rear tires before the front tires. hence no wing
00Maddog is offline   Reply With Quote
Old 01-08-2005, 05:59 PM   #13
wrxzolli
Member#: 69081
2004 WRX
World Rally Blue
sweet!
Old 01-08-2005, 09:50 PM   #14
cooparu
Member#: 67767
2010 WRX
Red
Yes, I remember the maddog yard sale...
cooparu is offline   Reply With Quote
Old 01-08-2005, 10:02 PM   #15
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
i raced at alaska raceway with my sub/amp in the trunk....ran like a 14.9 with it in...lol and when i took it out along with all my other junk, i ran like a 14.4....lol....my old car was slow...
AK_2002_WRX is offline   Reply With Quote
Rotors: Size vs Weight vs Diameter awd4ever Brakes, Steering & Suspension 21 02-17-2009 12:59 AM
audio system vs weight d3wu STi Forum Archive 20 05-19-2003 02:03 PM
Wheel size vs weight Cerum Brakes, Steering & Suspension 3 04-09-2003 12:53 PM
Offset vs. Weight? Murphy Brakes, Steering & Suspension 5 04-14-2002 02:23 PM
Traction vs. Grip Subaman General Forum Archive 11 05-11-2000 09:18 AM
