Old 01-06-2005, 03:04 PM   #1
quazimoto
Member#: 70395
Default Omori gauges using clock wiring?
With the Omori gauges in the dash pod can i use the clock harness ground,ignition lead for gauge,and the lighting lead for the lighting with out effecting the gauge?Or do i have to run a ground straight to frame for the gauge and gauge lighting to use?I'm not worried about dimming the gauge lighting.
quazimoto is offline   Reply With Quote
Old 01-06-2005, 10:20 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
Although I don't use gauges I believe many people use those wires.
brunetmj is offline   Reply With Quote
Old 01-06-2005, 11:01 PM   #3
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
Yes they will be fine. For the lighting many people use a wire from the stock radio harness, it is what the stock boost gauge uses for the dimmin light. But as for your question, yes you can use the clock wireing. It says what is what on the back of the clock for further help you.
Tur1smoWRX is offline   Reply With Quote
Installing gauges using clock power Wakeforce Electrical & Lighting 1 04-29-2009 04:51 PM
Help w/ Boost Gauge Install using clock wiring astrange22 Electrical & Lighting 1 09-14-2008 12:38 PM
FS Omori gauges in clock pod vortectoy Interior/Dressup/Audio & Security 7 05-16-2007 01:02 AM
gauge wiring clock wire ? help dark knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-14-2002 07:26 PM
Installing omori gauges....how to remove clock? wrxmontao!! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-04-2002 10:03 PM
