Old 01-06-2005, 03:19 PM   #1
Liam D
Member#: 50500
Default ? on switched power tap
I was going to install two additional cigarette lighters behind the dash to power an iPod and Satellite Radio. Can I tap the switched power off of the cigarette lighter under the HVAC controls? ('04 FXT). I can ground it to pretty much anything back there right?
Liam D is offline   Reply With Quote
Old 01-06-2005, 10:15 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
Sure. Here is an interesting thread I found on that topic from scoobymods. Personally I would prefer to use an independent wire to power the new 12 volt sockets using an inline fuse. That whole lighter system in a subaru is sensitive so I stay clear of it.
http://www.scoobymods.com/forums/showthread.php?t=1322
brunetmj is offline   Reply With Quote
Old 01-06-2005, 10:24 PM   #3
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Trunk_Monkey is offline   Reply With Quote
Old 01-06-2005, 10:27 PM   #4
Liam D
Member#: 50500
Thanks a lot brunetmj! That's going to be a lot of help this weekend.
I'm going to put an .75A inline fuse from the switched power.
Old 01-07-2005, 07:16 AM   #5
brunetmj
Member#: 8023
2004 2.5 RS
.75A inline fuse
That's a rather low amp rating. Is that normal for an Ipod?
I would have expected to see a 10 or 15 amp fuse.
Old 01-07-2005, 08:37 AM   #6
Liam D
Member#: 50500
Oops, you're right. The .75A is only for a switch, not the power for the cig lighters. For that, I've got to figure out what fuse is already there and what other loads it's taking. If there is a lot hooked up the the fuse that is for the stock cig lighter, I'll add a 10A fuse assembly.
Old 01-07-2005, 08:42 AM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You don't need anywhere near 10A for an Ipod or satellite receiver. At the most they might draw an amp or two apiece. If you're adding a separate line just to power these, a 5A fuse should suffice.
Old 01-07-2005, 09:21 AM   #8
Liam D
Member#: 50500
Actually, do I even need one at all? The cigarette lighter (3x I think) and power mirrors are on a 15A fuse already. Is an additional one necessary as long as I don't hook up a bunch of stuff at once?
Old 01-07-2005, 09:51 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes you should add an additional fuse. The 15A fuse protects the entire circuit, but won't do much to protect your individual devices from anything less than a direct short. A smaller fuse dedicated to your added accessories will help protect them from major damage or meltdown should one of them fail and draw an abnormal amount of current.
If the devices themselves have their own internal fuses then this might not be necessary.
Old 01-07-2005, 10:44 AM   #10
Liam D
Member#: 50500
Yeah, but for an additional $4-5 I might as well put a 5A there. Thanks for the help.
Tapping a switched power line on our cars? NewShockerGuy Car Audio, Video & Security 4 04-24-2008 09:48 PM
Need some advice on 12v switched power source MattSTi Electrical & Lighting 7 08-21-2004 02:55 PM
Hella power tap ctrexer Electrical & Lighting 3 12-03-2003 11:55 AM
power tap in MrBaggio Electrical & Lighting 20 08-01-2003 01:35 PM
12v power tap for EBC dark_rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-19-2003 06:09 PM
