Old 01-06-2005, 04:43 PM   #1
xlr8onu
Member#: 36015
2014 Grand Cherokee
Default Defi D-Gauge oil temp install ???
I currently have the gally plug and understand that I need an adapter for NPT to BSPT, I want to know how long the temp probe is and will it fit with no problems? do I need some sort of extension or will it go right in. I done searches and most adress autometer and Defi BF but not the set up i'm interested in. Does anyone have experiece with this particular set-up?
thank you,
Mitch
xlr8onu is offline   Reply With Quote
Old 01-06-2005, 05:57 PM   #2
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
With the adapter I bought from Lowes, I needed to drill out the interior of it so the probe would fit through it.
As for clearances, I'm not exactly sure. If you have room around the the probe for liquid to flow, you shouldn't need to worry about things. The pressure will push oil around the probe to give you accurite readings.
I have not had any issues with my D-gauge oil temp probe that I mounted in a sandwich adapter between the block and the oil filter.
AJ
AJ711 is offline   Reply With Quote
defi BF white oil temp gauge with greddy sandwich adapter Dark WRX Interior/Dressup/Audio & Security 20 01-23-2009 09:53 PM
OK: Defi BF amber oil temp gauge (metric) - $99 shipped benw Interior/Dressup/Audio & Security 5 04-11-2008 03:48 PM
WTB: Defi Link V2 Oil Temp Gauge steverx05 Private 'Wanted' Classifieds 0 03-03-2008 04:10 PM
fs defi gauges oil temp boost egt and controller in a ati pod 60mm 600 blueghost Interior/Dressup/Audio & Security 9 09-28-2007 01:53 PM
Defi D Gauge Oil Temp drewzter Private 'Wanted' Classifieds 1 02-13-2007 10:44 PM
