Old 01-06-2005, 08:19 PM   #1
dnolek
Member#: 19979
Default UTEC Logged RPM's are wacky?
What's the deal with the RPM signal on the UTEC log 1? It seems to jump around quite a bit. I was trying to extrapolate out acceleration, and you might as well forget it, since the RPM's on the log are practically useless. For example, I have loggs where the car is accelerating, and the RPM stays the same over the 2 steps, there was DEFINITELY no hesitation in torque. I just got a new clutch, and it is NOT slipping. Does anyone have any idea of how to get a better RPM signal, or why it jumps around so much?
Thanks,
Derek
Here's a log:
4035 +11.0 3.7 99 70 00 rich +20.3 56.0 +15.2 +0.3 290.00 3.4
4198 +12.7 3.9 98 80 00 rich +18.3 59.1 +15.6 +0.3 290.00 3.6
4357 +14.7 3.9 98 90 00 rich +17.0 65.6 +16.7 +0.5 290.00 3.6
4591 +15.7 4.1 99 90 00 rich +17.6 69.1 +17.6 +0.5 290.00 3.8
4789 +16.4 4.1 98 90 00 rich +20.4 76.0 +19.0 +0.5 290.00 3.8
4901 +17.4 4.1 98 100 00 rich +23.0 76.1 +19.7 -0.7 290.00 3.8
5089 +17.2 4.2 98 100 00 rich +24.5 79.6 +20.7 -1.2 290.00 3.8
5509 +17.2 4.2 98 90 00 rich +24.6 80.4 +21.0 -1.4 290.00 3.9
5509 +17.4 4.3 98 90 00 rich +24.7 84.4 +21.0 -1.3 290.00 3.9
5717 +16.6 4.3 98 90 00 rich +24.9 85.2 +21.0 -1.3 290.00 4.0
5509 twice in a row? I don't think so.
dnolek is offline   Reply With Quote
Old 01-06-2005, 09:07 PM   #2
mistaboosta
Member#: 68722
I have the same problem, my rpm's even decrease as the car is accelerating.
I wonder what would happen if I used a rpm input with LM-1.
mistaboosta is offline   Reply With Quote
Old 01-06-2005, 09:15 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
It's not a problem. From what I hear it's cause the utec doesn't give logging as high a priority as it gives other things(like running the car).
peace
Old 01-09-2005, 01:51 PM   #4
dnolek
Member#: 19979
Seems kinda pointless, for the UTEC to be posting RPM numbers that are not right. I would be happier if it was reporting something with less accuracy, like 1K, 2K, 3K, or 1200, 1300, 1400, instead of giving us bogus info.
Will utec log knock events in log when not in control? MAP 0 NITROS UTEC 1 08-21-2007 10:55 AM
Can't shift in to 3rd gear if rpm's are over 6k..? SolidSnake Transmission (AT/MT) & Driveline 6 05-03-2006 01:47 PM
UTEC Logs Graphed rlavalle Engine Management & Tuning 4 01-03-2003 11:43 AM
UTEC Log Filter Program 2000vfr800 Engine Management & Tuning 0 12-05-2002 03:17 PM
1st UTEC Log? Ideas? hotsam Engine Management & Tuning 1 11-29-2002 11:52 AM
