Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Old 01-07-2005, 12:17 AM   #1
blazerwrx
Member#: 39683
02 Forester S
Question charging problem after swap
i drove it for aday and it died on me... i changed the alternator and still the same, not charge while engine is running (staying a 12.46 volt and dropping) i changed the battery and still the same. what else could it be?
blazerwrx is offline   Reply With Quote
Old 01-07-2005, 12:47 AM   #2
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
did you wiring the alternator correctly? check if there are any loose wires.. and check if you ground everything correctly check for tightness..
taeyax82 is offline   Reply With Quote
Old 01-07-2005, 01:13 AM   #3
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Yeah, the alt should be able to keep the engine running w/out help from the battery. Double check your main wiring connections.
tooocool49723 is offline   Reply With Quote
Problem after swapping out the bulbs bebechica Electrical & Lighting 2 12-25-2008 03:51 AM
Having fuel problems after swap Toahk Subaru Conversions 4 09-30-2008 07:48 AM
speed sensor problems after swap gazdie Subaru Conversions 2 07-12-2008 08:47 AM
problems after swap living4surf Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 03-30-2007 04:35 PM
heater problems after swap RFoy91TSi Subaru Conversions 5 12-20-2005 07:39 PM
