Old 01-07-2005, 01:04 AM   #1
WRXakaBooSTi
Member#: 61119
2004 Stock WRX
Default Anyone else's WRX sound like its about to die out before it starts up?
Ive had my WRX for about 8 months now. Within the last 2 months or so I've begun noticing that whenever i start the car it starts up funny. When i turn the key, the engine fires up but then sorta of "dips," then gets going normally. It doesnt start up in a smooth motion because during startup theres a point where it seems like its about to die out but then gets going just fine. i think this usually happens when the car hasnt been driven for a few hours; when its cold. (my engine is stock)
Anyone else have this prob? what could it be?
WRXakaBooSTi is offline   Reply With Quote
Old 01-07-2005, 01:45 AM   #2
XS_WRX
Member#: 61519
2004 Subaru WRX
cammed,built,35R'd WRSTi
thats normal.... it goes up then dips to about 300 RPM then goes back to 1k..
I have a stg4+ car and it does this every time i start up.. sometimes not as dramatic but it does it... also, do you have a bov? a poorly tuned bov will cause idle/stalling problems like the ones you've described above. The car cranks up and dips below 500RPM and it sputters and kicks back up to 1k then goes down and will eventually die out.
-alan
XS_WRX is offline   Reply With Quote
Old 01-07-2005, 03:46 AM   #3
wrXiconZ
Member#: 53085
2004 Wrx Impreza
Java Black Pearl
my car is stock and does this too. i always thought it was normal... if its not tell me!
wrXiconZ is offline   Reply With Quote
Old 01-07-2005, 03:51 AM   #4
Drive4Ever
Member#: 65376
2004 Impreza WRX
my car does it every now and then, its normal
Drive4Ever is offline   Reply With Quote
Old 01-07-2005, 10:38 AM   #5
WRXakaBooSTi
Member#: 61119
2004 Stock WRX
no bov. but it never did it in my first few months. it just started recently.
Old 01-07-2005, 11:06 AM   #6
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
Mine did that when the battery was low on water.. and when its cold like now.
Subie2 is offline   Reply With Quote
Old 01-07-2005, 11:16 AM   #7
Silver04WRX
Member#: 37644
2009 Legacy 2.5i
Mine does it when the engine is warm
Same thing as this guy:
http://forums.nasioc.com/forums/show...t=warm+startup
Silver04WRX is offline   Reply With Quote
Old 01-07-2005, 12:25 PM   #8
jstbstn
Member#: 35020
02 WRX - Stage WTF
04 WRX Wide Wagon - Stg 3
mine used to do this, and then I just tried letting the fuel pump prime a second or two longer and no more issues. You can hear the pump prime when you turn the key all the way to on and leave it there for a second before cranking it... seemed to cure the problem for me.
jstbstn is offline   Reply With Quote
Old 01-07-2005, 12:42 PM   #9
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
that seem to be normal thing with wrx.. even my brand new 05 does the same thing..
esp when it's warmed up.
Kenji815 is offline   Reply With Quote
Old 01-07-2005, 01:03 PM   #10
Aegon
Member#: 42435
Do this
Aegon is offline   Reply With Quote
Old 01-07-2005, 02:26 PM   #11
subieworx
Member#: 47769
Had the same problem. Now I do what is described above about priming the pump and have not had a startup problem since.
subieworx is offline   Reply With Quote
Old 01-07-2005, 03:05 PM   #12
subaru.ca
Member#: 77240
2004 Impreza WRX
I also had the same problem after a few months from new. One time it actually stalled.
subaru.ca is offline   Reply With Quote
Old 01-07-2005, 03:16 PM   #13
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
I let the fuel pump prime as well. It starts up quick in the cold but when its warm, it feels like it struggles more to start. Just turn the key and start putting your seat bellt on and by the time your done, it should be primed and then start.
darksands is offline   Reply With Quote
Old 01-07-2005, 03:44 PM   #14
subalou1
Member#: 57966
2002 wrx Sedona Red
[email protected], best trap 131
yeah when mines warm it does that also, it even stalled once
subalou1 is offline   Reply With Quote
Old 01-07-2005, 03:45 PM   #15
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
fuel pump primer here!
wcbjr is offline   Reply With Quote
Old 01-07-2005, 04:15 PM   #16
subieworx
Member#: 47769
This makes sense if you think about it. When warm all metal parts in the engine are fully expanded and will increase the amount of cranking amps needed from the battery to turn the starter to get the pistons moving. When everything is cold there is less compression and more blow by so the battery does not need to supply as many cranking amps to get the car started.
Old 01-07-2005, 05:01 PM   #17
elsanto
Member#: 34832
1989 M3
i ALLWAYS have to turn my key twice before getting a start in this weather (East coast) It bothers me but not enough to get it looked at. i turn the key let it crank 3 or 4 times. turn off.. turn the key a second time and it fires ont he first shot... mind you i prime the FP before the first turn
elsanto is offline   Reply With Quote
Old 01-07-2005, 07:29 PM   #18
rexpdx
Member#: 34729
06 WRX Wagon CGM
01 2.5RS coupe white
Nope. My WRX starts 2 cranks when cold, 3 cranks when warm, every single time without fail. No dip.
rexpdx is offline   Reply With Quote
yup its going to get worst before it gets better... lionken07 Off-Topic 40 01-26-2009 03:02 PM
Drivetrain feels like its going to fall out of my car... turbotoyzz Transmission (AT/MT) & Driveline 0 10-13-2006 09:16 PM
help!!! car sounds like its dying kcook Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-22-2006 08:51 PM
Anyone else's legacy sound like a Deisel? PhoenixDownVII Legacy Forum 7 12-27-2005 04:46 PM
my ear feels like its going to explode out the side of my head... I ROBOT Off-Topic 13 07-05-2004 03:47 PM
