Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 01-07-2005, 09:55 AM   #1
scoobie
Member#: 816
2010 Tacoma DC
Gray
Default help oil on spark plug wires and
I have oil on my #1 spark plug wire and there is oil around the top portion of the plug most likely from leakage down the tube. I pulled the plug and it is fine whitish dust. Also there is an egg smell coming from the exhaust, There is also the issue of coolant disappearing and the engine started to overheat till I added water and it has been fine for now.
scoobie is offline   Reply With Quote
Old 01-07-2005, 10:33 AM   #2
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
blown head gasket?
Ru fan is offline   Reply With Quote
Old 01-07-2005, 12:10 PM   #3
sha_zapple
Member#: 41012
1998 Legacy L
Perhaps you didnt have the plug tight enough, or theres an extra crush washer in there.
Coolant dissapearing and the engine overheating definitly sounds like a head gasket issue. The 2.5L's have a bad tendancy to do this.
sha_zapple is offline   Reply With Quote
Old 01-07-2005, 03:40 PM   #4
Diz
Member#: 874
2004 Porsche 911
2004 Mazdaspeed MX-5
Make sure that it's actually oil. It's common for the PS pump to leak around that area.
Diz is offline   Reply With Quote
Old 01-07-2005, 08:02 PM   #5
scoobie
Member#: 816
2010 Tacoma DC
Gray
Not the head gasket just a bad spark plug gasket on #1, once i picked up the parts only took 30 mins.
no oil found in coolant, also this morning there was no condensation under the oil cap.
problem now is i am getting a #3 misfire, I have all new plugs, all of the injectors are firing you can hear them tick through a screwdriver, i also pulled the plug wires at both ends one at a time and you can either see spark of hear spark.
Any ideas?
Old 01-16-2005, 02:43 PM   #6
John2.5RS
Member#: 1140
2013 Ecoboost'd F150
Grey
perform a leak down test. open radiator cap and look for bubbles. You may be leaking coolant into cyl #3.
John2.5RS is offline   Reply With Quote
Old 04-11-2005, 10:27 PM   #7
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
I have engine oil in all 4 plug ports/boots. All 4 plug gaskets are bad? Please tell me what I need and how to change them. Also NO engine oil in coolant.
Jerry Xu is offline   Reply With Quote
Found oil on spark plug wires rubberman Service & Maintenance 6 10-25-2011 02:38 PM
NGK Spark Plug Wires and Distributor snowcrzy 1993 - 2001 Impreza Specific Parts 7 07-31-2007 11:19 PM
Spark Plug Wires and Perrin Intake MAF charge hose Lachlan Private 'For Sale' Classifieds 1 02-12-2006 01:11 PM
which spark plugs, wires and coil packs willdh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-18-2004 01:39 AM
Oil on spark plug wires normal HighTachPrez Normally Aspirated Powertrain 1 05-21-2003 02:36 AM
