Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-07-2005, 11:29 AM   #1
bryan_johnson
Member#: 78987
Default Engine/Pan Dimensions?
I'm putting a subaru motor in a vanagon and understand that some of the turbo motors like wrx have a shorter oil pan than a normally aspirated 2.2L or 2.5L. I'm thinking of putting a 2.5L turbo motor in the van. Does anyone have any dimensions for how far pans for various motors extend below the block? Also any other overall engine dimension info would be greatly appreciated.
Thanks,
Bryan
bryan_johnson is offline   Reply With Quote
Old 01-08-2005, 01:00 AM   #2
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
The WRX pan is actually a little bigger and might hang a little lower. It also has extra baffling so if you plan on running circut type events, get a wrx pan. Otherwise any RS or L pan will work fine for you.
Sorry I don't have more info for you.
Chad
www.uniquemotorsports.com
subachad is offline   Reply With Quote
ej257 engine feeler C-DAY Engine/Power/Exhaust 38 06-12-2010 02:18 PM
EJ20 Engine Mounting Dimensions? dreamtech Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-01-2009 07:09 AM
exterior dimensions of 2.2l & 2.5l engine & manual transmissions needed. JW2 Newbies & FAQs 0 05-25-2008 02:09 PM
Oil Pan installation, Engine Jacking Points Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-23-2007 03:24 AM
Engine dimensions tonyakavw Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-12-2005 06:08 PM
