Old 01-07-2005, 03:33 PM   #1
b0dh1
Member#: 35269
2011 WRX
Default TMIC vs. FMIC with UTEC
I figured this subject would've been beaten to death but my searches came up pretty empty. I have a TMIC on my car now and my TXS FMIC should be here tomorrow. Should I completely get the car re-tuned or are the changes easy enough for me to make? I don't have a WB02 however.
2003 WRX mods:
Vf23
modded injectors
TXS UTEC
TXS shorty
TXS FMIC(TMIC until tomorrow)
Catless uppipe
Invidia d/p
Carbon/Ti catback
Perrin inlet hose
BKR7E plugs
b0dh1 is offline   Reply With Quote
Old 01-07-2005, 06:40 PM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
I don't know if my experience was "normal" but my tune (fuel-wise, anyway) was TOTALLY borked after putting an FMIC on.
It wasn't dangerous really, just exceptionally rich in the low-load areas (from 12.5ish to 10.5ish). There were some spots around 70% and certain low RPM that were lean, but I *think* that was caused by other changes I'd been making in my maps but hadn't noticed until after the FMIC install.
serendipity is offline   Reply With Quote
Old 01-07-2005, 07:27 PM   #3
jlee8196
Member#: 22211
I have a stock IC before I switch to Turboxs FMIC. My original map was rich everywhere. If you looked at the stage4TMIC map v.s. the stage4FMIC map on turboxs you'll see that fuel is less on the FMIC map almost everywhere. The timing is the same.
So only fuel map needs to be tune. The only safe way to tune fuel..... yep wideband. So re-tune in your case, you should think about getting a tuna or other WBo2's with all your setups.
jlee8196 is offline   Reply With Quote
Old 01-07-2005, 07:40 PM   #4
b0dh1
Member#: 35269
2011 WRX
Thanks for the replies. I'd love to get a tuna but after this FMIC project it's time to pay the bills. Down the road is possibly a bigger turbo and one last tune
tmic vs. fmic for 02 wrx sleeper 2 Factory 2.0L Turbo Powertrain 4 01-12-2013 03:04 PM
TMIC or FMIC with UTEC Stage 3 EA704life Vancouver Impreza Club Forum -- VIC 18 12-04-2004 02:05 PM
TMIC vs FMIC WRteXmeX Texas Impreza Club Forum -- TXIC 16 11-22-2002 01:58 PM
TMIC vs. FMIC. questions and pro/con Redneck Ricer Factory 2.0L Turbo Powertrain 14 09-20-2002 02:59 PM
tmic vs. fmic sleeper 2 Factory 2.0L Turbo Powertrain 12 08-24-2002 11:53 AM
Message Board Statistics All times are GMT -4. The time now is 05:00 PM.
