Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 01-07-2005, 09:40 PM   #1
jefersun
Member#: 37716
2002 ej257 Black WRX
Default Is it safe to turn the knock sensitivity down on a Utec?
Just as the title says, is it safe to do so? The reason i'm asking is because i get 01 knock counts in vacuum mostly around 2000 rpms. This happens a lot and i get 01 knock counts in other parts of the rpm band (below 3500 rpm) just driving normally, all in "negative" psi regions. What should i turn the knock sensitivity down to? I hate my CEL going off when im going from 35 to 40 in 5 seconds...
jefersun is offline   Reply With Quote
Old 01-07-2005, 09:49 PM   #2
Physics Junkie
Member#: 65609
Whats the knock sensitivity set at right now?
Physics Junkie is offline   Reply With Quote
Old 01-07-2005, 10:16 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Do a compression check on the engine.....post the #'s
Uncle Scotty is online now   Reply With Quote
Old 01-08-2005, 04:58 PM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
do what scotty suggests.
Old 01-08-2005, 08:09 PM   #5
jefersun
Member#: 37716
Yea i'm doing it tomorrow, i'm betting on low compression in #4, any other bets?
Old 01-08-2005, 09:03 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
I'd bet on a coil pack bein fried from runnin a wide gap, course I'm probably wrong.
Old 01-08-2005, 09:17 PM   #7
jefersun
Member#: 37716
As you probably know from all my other threads, i regapped my plugs. They were initially at .04 when i took them out, put them to .027 now. How do i test for that though? might as well, i'm gonna be in there anyways doing the compression test...
Old 01-08-2005, 09:36 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
Really, I don't even know that having a wide gap would cause any damage to a coil. I just figured it was logical. If you always have the knock problem on the same cylinder, switching the coil pack on that cylinder with a different one would be a good test. If the problem follows the coil pack, you have your culprit.
peace
Is it safe to turn boost up with a Manual Boost Controller? undrgroundskat3r Newbies & FAQs 17 07-22-2010 11:33 PM
Is it safe to move the coolant reservoir? Where All4bSpinnin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 03-22-2008 12:00 AM
Is it safe to ground the parking switch? e177ery Car Audio, Video & Security 7 01-02-2006 05:27 PM
Is it safe to brush the snow off the car with a broom? driver General Community 38 11-29-2004 06:56 PM
Is it safe to turn my turbo charger up to 22lb livewirevoodoo Newbies & FAQs 29 11-24-2001 01:51 AM
