Old 07-09-2001, 12:50 AM   #1
KEVINL
Member#: 3525
2004 Duramax W/500HP
And Want another STi
Default Help needed! strange problem
Hi I own A 1992 SVX and under WOT after it shifts the car will hit a huge dead spot and then start accelerating again. Although you can almost floor it and it wont happen is it something to do with the TPS
any ideas would be greatly appreciated
Thanks
KEVINL is offline   Reply With Quote
Old 07-09-2001, 01:16 AM   #2
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Sounds like a fuel delivery problem. I would use some high test detergent gas, and maybe get some of that injector cleaner additive. When was the last time you changed out the fuel filter? Might want to check that too.
Keep in mind these are all just guess's. I have never seen a SVX let alone work/own/drive one.
ChosenWon is offline   Reply With Quote
Old 07-09-2001, 03:02 PM   #3
KEVINL
Member#: 3525
I dont believe its fuel delievery because near full throttle the car is perfectly fine the car runs awesome dont have any other problems no pinging surging or stalling
Old 07-09-2001, 07:54 PM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Has it always done that? Or, did it start doing this recently?
00/01 RS does that. At least mine does. As you step on the gas to full throttle, it feels like the car loses power for a split second and accelerates.
We came to a conclusion that it happens because of the fuel map in our engines. I've been looking at the A/F meter and stuff, but all I see is "rich" at WOT.
tmat3 is offline   Reply With Quote
Old 07-09-2001, 08:01 PM   #5
ChosenWon
Member#: 2236
2000 Audi S4
Well I have to stick by my original theroy. Yes, as you stomp on it, it will get gas, it's when you go from no/let off gas (for shifting) and then go back to full wot that you see the hesitation. That is because the fule is getting full stream through whatever blockage,and then you let off and the blackage resettles and then as you stomp on it, it has to get by that blaockage again to get back in the "grove".
Well whenever you figure it out, please let us/me know. I am very curious.
BTW, I had this exact problem on two diff cars. One had to have the carb rebuilt and the other was a bad fuel filter.
Old 07-09-2001, 09:29 PM   #6
KEVINL
Member#: 3525
Default update
Okay now I know something is jacked it will do it if I put it in manually mode and shift at 3K RPM it still does it. Also it does it bad I mean you can be 2 car lengths ahead at the end of first gear and by the time the car starts accelerating youll be 3-4 car lengths behind just because of this problem
BTW it didn't always do it I was racing someone one day it happend I lost the race and its happend ever since
Old 07-10-2001, 12:56 AM   #7
ChosenWon
Member#: 2236
2000 Audi S4
Has your mileage gon down? Maybe you have a leak in the fuel line? Due to extreme pressue from the race?
Old 07-10-2001, 01:02 AM   #8
KEVINL
Member#: 3525
gas mileage has always been consistent I never smell any gas
Old 07-10-2001, 01:31 AM   #9
subpreza
Member#: 2940
2002 AMG C32
Black Opal
Could be a valve problem. Do a compression check.
subpreza is offline   Reply With Quote
Old 07-10-2001, 09:37 AM   #10
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Question
is your tranny slipping?
i know SVX's and their tranny's...
how many miles are on yours?
are you hearing anything at all or is their dead silence and massive hesitation...?
j.
www.subiegal.com
Old 07-10-2001, 01:26 PM   #11
GGrahnVI
Member#: 7190
Bothered to check the brand of gas your putting in? The symptoms you describe sound a lot like detonation of some sort and the ECU is yanking your timing. Probably as someone else said, a fuel problem. How many miles on your fuel filter? Do you always put in the best gas you has availible? What kind of spark plugs do you use?
In order to properly diagnose this kind of issue, we would need to know any modifications you have done to your car.
GGrahnVI is offline   Reply With Quote
Old 07-10-2001, 07:56 PM   #12
KEVINL
Member#: 3525
Okay I run Texaco premium so I doubt thats the problem besides under wot 2-3 shift is fine. Its a brand new tranny the old tranny did the same thing. Its turbo and rear wheel drive
Old 07-11-2001, 05:26 PM   #13
KEVINL
Member#: 3525
BUMP*
Serious help needed, Shifter problem mems3 Transmission (AT/MT) & Driveline 2 08-26-2009 06:12 PM
major help needed 2 problems with car..!! please all look.. evol04gt Service & Maintenance 13 04-24-2008 12:39 AM
need help with strange problem mklier1218 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-12-2005 11:48 AM
Calling all coilover owners for help on strange problem with my JIC's. west Brakes, Steering & Suspension 22 05-31-2005 09:16 PM
Help needed! strange leak perhaps, loss of power?!? MarkyMark Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-27-2003 10:16 AM
